To much heat!!!! Help
Old May 30, 2013 | 08:08 PM
ywellw's Avatar
It gets to hoootttttt under my hood to the point that, when you touch anything even the CAI it burns your hand! How do I reduce the heat?
Old May 30, 2013 | 08:11 PM
nttstt444's Avatar
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/ultimate-cooling-mod-739098/ ultimate cooling mod thread
Old May 30, 2013 | 08:36 PM
CLtotheTL32's Avatar
It's getting hot in here...
Old May 30, 2013 | 08:40 PM
ywellw's Avatar
Damn right it is!!!! To HOTTTTTTTT LOL
Nick216's Avatar
The Boss
engines get hot? tb bypass,remove plastic covers, insulate ure cai, tb spacer. I miss anything? Unless your coolant is low
Old May 30, 2013 | 08:41 PM
ywellw's Avatar
nttstt444 .....Thanks for the link, but that is ugly! I think ill just cut slots or drill holes!!!
Old May 30, 2013 | 08:43 PM
ywellw's Avatar
Im kinda new to this whole page, Ive tried to search how to do the tb bypass but I get nothing. I need to work on my searching skillz
Old May 30, 2013 | 08:47 PM
Nick216's Avatar
The Boss
Red text = sarcasm , and how hot are we talking, like was ure thermostat above half? unless your car wasnt even on
Old May 30, 2013 | 08:52 PM
ywellw's Avatar
No it was normal, its just when I popped the hood everything was extremely hot, I mean I know its gonna get hot under there but damn I could fried chicken under there... My car also felt a loss of power and im pretty sure its bc of the heat
Old May 30, 2013 | 08:57 PM
Nick216's Avatar
The Boss
people claim the TB bypass helps with heatsoak, wich is why you lose power. as i literally did the bypass this morning. the tb bypass is just going to make ure throttle body cooler, but ure engine will most likely still be an oven.i forget wich thread i used for instructions, but as im on my phone i cant link it to u, im sure u could find it though.
Old May 30, 2013 | 09:02 PM
ywellw's Avatar
Im going to keep searching unless someone can send me the link, Thanks for the help! I think I might just take the hood off and ride around like that LOL
Old May 30, 2013 | 09:45 PM
EvilVirus's Avatar
OP use google.........Acura TL TB bypass
Old May 30, 2013 | 09:59 PM
Nick216's Avatar
The Boss
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/tb-coolant-bypass-mod-anyone-do-638323/
Old May 30, 2013 | 10:11 PM
ywellw's Avatar
Old May 30, 2013 | 10:37 PM
Italiano's Avatar
Old May 31, 2013 | 12:24 AM
anx1300c's Avatar
Old May 31, 2013 | 07:10 AM
AZP-TL's Avatar
LOL, welcome to the world of the internal combustion engine. An ICE is a very inefficient machine, most of the energy is wasted in heat under the hood and out the exhaust; there's really not much you can do about it. Removing the plastic or the hood will only net you minute gains. Adding a turbo charger makes use of some of that wasted energy and is the best way to increase efficiency and performance. If you're worried about the heat, don't be, the car and the components were engineered for it.
Old May 31, 2013 | 09:07 AM
losiglow's Avatar
^ Word. Most engines are about 25-30% efficient. So 70-75% of the fuel burned is converted to heat. Pretty depressing really.
Old May 31, 2013 | 09:15 AM
Undying Dreams's Avatar
Old May 31, 2013 | 09:58 AM
ywellw's Avatar
Well let me ask you guys something, when I'm going 60 and I go to pass someone my car creeps by instead of flying by..... what could be the cause of that? It just started doing that and I thought it could of been bc of the heat
Old May 31, 2013 | 10:20 AM
jisleyjr's Avatar
The cause is that they are going 59 mph. You might be able to fly by someone that is only going 50 mph.
Old May 31, 2013 | 12:09 PM
HQTL6SPD's Avatar
The UCM should highly be considered by those in very hot climates. Too much heat can actually result in becoming a big expensive headache..
Heres an example of what happened to me:
https://acurazine.com/forums/showpos...9&postcount=30
Old May 31, 2013 | 12:14 PM
Comptechtl2367's Avatar
The UCM is just plain ugly. It makes a beautiful car look cheap and ugly. If I were you I wouldnt worry about it.
Old May 31, 2013 | 01:22 PM
1black_seven's Avatar
Slot Machine Lubricator
There's a thread on here of a guy who bought hood vents from a BMW and installed them onto his hood.
Was functional and looks a lot better than the UCM.
Old May 31, 2013 | 01:28 PM
I cant find the thread for some reason. But there is a similar thread in the TSX section.
Old May 31, 2013 | 01:47 PM
TheLowLife's Avatar
Old May 31, 2013 | 02:05 PM
ywellw's Avatar
Ok there are two tubes under the tb , When I remove them where the hell do they go????LOL Im trying this bypass
Old May 31, 2013 | 02:32 PM
Nick216's Avatar
The Boss
both hoses under the tb go away. when youre done you should have 2 extra hoses from that spot. be ready for coolant to spill out, i got that shit in my mouth and it was horrible. save everything so you can change it back for the winter, idk how cold it gets near you.
Old May 31, 2013 | 02:41 PM
ywellw's Avatar
LOL your mouth???? LMAO!!!! Thanks
Old May 31, 2013 | 02:59 PM
pohljm's Avatar
that could be a part of the problem but its more than likely an automatic transmission in a 3000+ lb car with little torque. Strange as it sounds it could also be the battery.
Old May 31, 2013 | 03:21 PM
ywellw's Avatar
Your right it could be the battery, being that I just installed a system in my car! I got the tb bypass done and thanks for the help fellas
Jul 16, 2017 07:33 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
TL14
Sep 24, 2015 04:37 PM
