MPG 2 months after AEM
Old Apr 11, 2009 | 06:36 PM
  #41
chill_dog's Avatar
Oderint dum metuant.
Nice. I haven't noticed a change in my mileage from any mod, positive or negative...21 overall, no matter what. Of course, I don't normally do enough driving to try to do a detailed city/highway analysis like that (don't really care, either ), but if I go on a trip, I'll clear it and see what comes up...got 33/34 to/from the beach the other year.
You know, if the wife didn't mind the intake, you might as well get an exhaust, too .
Old Apr 11, 2009 | 07:31 PM
  #42
Trew's Avatar
http://www.dailyfueleconomytip.com/u...ur-air-filter/
Old Apr 11, 2009 | 07:45 PM
  #43
jeowen's Avatar
Originally Posted by I hate cars
When will these crazy claims ever stop. A dirty airfilter does not decrease mileage. A CAI does not increase mileage.
The manufacturer would kill for a 4mpg boost. They did all this testing on 20wt oils just for the 0.5mpg boost. Don't you think every TL would have a factory CAI if it helped this much?
Thats just BAD, completely WRONG information
Old Apr 11, 2009 | 07:55 PM
  #44
I hate cars's Avatar
The info is 100% correct. You need to do some research before you call my info incorrect.
Old Apr 11, 2009 | 07:56 PM
  #45
That's a very old "study". I'll dig up the one that was done this year that proves what I've been saying for years.
Old Apr 11, 2009 | 07:57 PM
  #46
AngeloUCF's Avatar
'05 6MT w/Nav A-Spec
Click HERE. See the 3rd myth buster at the bottom.
Old Apr 11, 2009 | 07:58 PM
  #47
Try this: http://www.fueleconomy.gov/feg/pdfs/...02_26_2009.pdf
Old Apr 11, 2009 | 08:08 PM
  #48
jeowen's Avatar
Thats a good find, however the study posted earlier that you referred to as "old" states the opposite. All I can refer to is what I have experienced/ seen and that is gains in the MPG, now ifs that is the result of an "optimistic MID" or "wishful thinking" I do not have the answer. However I am not the only one on this forum, or that has commented on this thread about my numbers being accurate/ comparable to other members, and you dont need to be telling me what i "need to do" before I post.
Old Apr 11, 2009 | 08:09 PM
  #49
Trew's Avatar
Interesting read, Matt...
I still think fuel economy will be ultimately negatively affected by a dirty filter since you would have to push the car harder to maintain the same throttle response, thus burning more fuel.
Old Apr 11, 2009 | 09:35 PM
  #50
When you tell me I'm full of crap when in reality I'm right, that means you need to do more research. The whole dirty airfilter equals worse mileage is one of the oldest and most believed myths out there. This was true back in the carbureted days.
Old Apr 11, 2009 | 09:39 PM
  #51
It won't and the reason for this is you're pushing the throttle further to get the same airflow with a dirty filter than you would have to with a clean filter. The net effect is the same airflow resulting in the same mpg.
The only difference would be with an automatic where the computer sees a larger throttle opening so it shifts a little later.
Old Apr 11, 2009 | 09:57 PM
  #52
jeowen's Avatar
Clearly there have been more that one study on this topic, with contradicting results. Thus I am forced to post the only information that I believe to be true, that information is based on what I have personally noticed based on MY car, with MY driving tactics. The numbers that I have witnessed (which is MY reality )force me to believe that the CAI mod to MY car has lead ME to a MPG increase.-
Old Apr 11, 2009 | 11:45 PM
  #53
I wouldn't call them studies. More like internet propaganda. Nothing more than someone's opinion posted as fact.
Once you understand how EFI works, both speed density and mass air and the relationship of vacuum, airflow, 02 sensor readings, long term fuel trims, etc, you will realize it is absolutely impossible for a restriction in the intake tract to cause worse gas mileage.
What do you think the throttlebody is? It's an adjustable restriction. Going by the arguments on here you would get worse mileage with a partially closed throttle (restriction) rather than with it wide open (no restriction).
All a plugged airfilter can do is limit full power.
Old Apr 11, 2009 | 11:51 PM
  #54
usc's Avatar
usc
^ But if you tell people the truth, then air filter companies will sell less products, then they'll be forced to lay off more people, file for bankruptcy, and send the economy down the toilet.
Oh wait... the economy is already f'd.
Old Apr 12, 2009 | 12:57 AM
  #55
Rob RiL's Avatar
Unregistered User
So wouldn't you end up using more fuel by having to accelerate harder to compensate for the lost power caused by the dirty air filter? I understand the computerized argument, which does make perfect sense. I just would guess that you'll mash out to do what you could normally do with a clean filter, thus burning more fuel.
Old Apr 12, 2009 | 01:01 AM
  #56
Rob RiL's Avatar
Unregistered User
Originally Posted by lemonade
Also alignment, sometimes people forget that, bad alignment get you worse mileage too.
This is very true. I believe the technical term is 'increased rolling resistance'. I installed a Ingalls rear camber/toe kit and then drove almost 200 highway miles back to where I live. My mpg to the install location was 23.9. My mpg back was 27.7. Then I aligned it later that day and the mpg raised a bit more. I'm a very happy camper now.
Old Apr 12, 2009 | 01:28 AM
  #57
No, because you're mashing down on the accelerator just to get back up to the same airflow as you were at with a new filter. Total airflow is the same so no extra fuel is used. The pedal only controls the airflow. The computer matches fuel based on airflow, not throttle position.
Old Apr 12, 2009 | 01:37 AM
  #58
Rob RiL's Avatar
Unregistered User
Yea, that does make sense. Hmm. So, are you saying a dirty air filter causes just a decrease in performance? I was always taught differently but everything you said about efi is correct. ....*ponders away*
Old Apr 12, 2009 | 01:41 AM
  #59
It took me a while too. I had a ton of "ifs" at first.
With a carbureted car, which is where this originally came from, a dirty air filter increased vacuum through the carb which made it run rich and decreased fuel economy. This myth carried over to fuel injection unfortunately.
Old Apr 12, 2009 | 01:54 AM
  #60
Rob RiL's Avatar
Unregistered User
I just figured the extra compensation of opening the throttle to get the restricted air unrestricted would result in more, unneeded combustion. But everything you said makes absolute sense. I'm going to talk to a few people about it because now I'm curious.
I never did see how a cai would save fuel. If you consider a blown motor, you have to use more fuel when you accelerate to mix with a higher flow of air. So, besides a nice increase in power, I didn't understand the higher mpg claim.
This is an interesting subject.
Old Apr 12, 2009 | 01:02 PM
  #61
javamanbill's Avatar
J Bill
^I agree with above poster. I do mostly city driving and best I could manage in my TL was around 22/23 city driving pretty conservatively. That didn't change after CAI.
Old Apr 12, 2009 | 01:30 PM
  #62
ALS2000's Avatar
Thanks "I hate cars." I always thought a CAI would improve fuel economy. But clearly it does not from your strong evidence. Even in the original posted study (comments section) there is mention that the data is from 1981. I had to read your study over a few times to understand the concept that stepping on the gas pedal controls the air..which then controls amount of fuel..not the other way around. correct? haha. still not sure but I think that's right. nevertheless thanks for clearing the concept up for me. I was almost considering a CAI for fuel economy. I don't really care too much about the "iffy" performance gains. I guess I'll pass on it now.
Old Apr 12, 2009 | 01:58 PM
  #63
TulsaTL6's Avatar
For what it's worth, when I got my new wheels and Tires (A-Specs & Goodyear Eagle GT) my Highway (65-75mpy) MPG went from around 29 to 32. I also got a 4 wheel alignment, and I had the tires filled with Nitrogen, so that may have played into it. Even with mixed, "spirited" driving I get aorund 22mpg all-purpose.
Old Apr 12, 2009 | 02:21 PM
  #64
Rob RiL's Avatar
Unregistered User
Proper inflation and a good alignment (just recently) gave me an extra 4 mpg. I was shocked but it makes absolute sense. If all four corners are even (with correct psi and alignment), then the car isn't 'dragging' extra weight. I don't think the nitrogen itself is saving fuel over regular oxygen, it's just that it supposedly keeps the tires around the correct psi because the molecular structure is less able to exit the tire. ....or something like that. Hah. I read about it before. Very scientific stuff.
Old Apr 12, 2009 | 08:57 PM
  #65
iraqura's Avatar
I get round 20 city n bout 28 hwy.
07 TLS w/AEM CAI 6mt
Jul 16, 2017 07:33 AM
lanechanger
Oct 13, 2015 10:56 AM
rangomango
California
Sep 24, 2015 05:47 PM
