Mobile1 5w-30 special
Just thought I'd pass this along for those who use Mobile1 5w-30 full synthetic.... Advanced Auto Parts is having a special for the entire month of June where you can get 5 quarts of full synthetic, and the Mobile1 filter for 28 bucks. I know the filters are usually a bit pricey so this is a good deal. - Thought I'd share
Registered Member
Around two weeks ago, they had the same sale offer in my area for $26.38 as I recall. I took advantage of it and have the goods in my garage right now.
2008 KBP Type S
fram = shit
Do you guys save the 1/2 quart from the walmart jug? I just dump the used oil back in there and waste the leftover new oil. I could have a "free" oil change every ninth time if I wasn't so lazy.
its crazy how alot of people dont even know that u can get the 5 quart jug of mobil one at walmart. i always see a bunch of guys buying 5 quarts at autozone for 6 bucks a piece
you would think the automotive place is cheaper but it seems like everything is more expensive there
Originally Posted by jnc2000
but the kicker here is $28 for a mobile1 oil and filter... IDK about you but I would never put a fram filter on my TL....
B16 Swapped TL
http://www.knizefamily.net/minimopar...ers/index.html
More than you ever wanted to know about oil filters. Looks like they recently updated their website.
The last time I read an Oil filter comparison FRAM used low quality filter material and material overall when compared to the competition. Lower Quality Filter + Less filter material = not filtering as much as possible.
B16 Swapped TL
Let's take two filters for the same vehicle as a comparison.... Fram Vs Mobil 1....
Fram Double Guard:
Average Retail Price $10
Cartridge Length 4.13 inches
Cartridge Outside Diameter 3.00 inches
Cartridge Inside Diameter 1.63 inches
Cartridge Pleats 38
Cartridge End Cap Type Cardboard
Anti-Drainback Valve Type Nitrile rubber diaphragm
Bypass Valve Type Nitrile rubber, integral
Element Type Paper media, stamped metal seam
Element Length 47.5 inches
Element Width 4.06 inches
Element Surface Area 193 square inches
Shell Thickness 0.015 inches
Backplate Thickness 0.18 inches
Gasket Type Nitrile rubber
Mobil 1:
Overall Length 5.44 inches
Overall Diameter 3.67 inches
Cartridge Outside Diameter 3.36 inches
Cartridge Inside Diameter 1.69 inches
Cartridge Pleats 55
Cartridge End Cap Type Stamped-steel, with bypass valve in front
Bypass Valve Type Spring-loaded steel, nitrile seal
Element Type Synthetic media, glued seam
Element Length 89 inches
Element Width 4.0 inches
Element Surface Area 356 square inches
Shell Thickness 0.018 inches
Backplate Thickness 0.14 inches
Same price essentially but you get more filter with the Mobil 1
Fram Double Guard:
Cartridge Pleats 38
Mobil 1:
Cartridge Pleats 55
navtool.com
31
11-16-2015 08:30 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
polish_pat
09-25-2015 12:24 PM
