MID DRL Error
Old Mar 25, 2012 | 04:01 PM
The Machine's Avatar
Registered Member
MID DRL Error
So I am curious as to what the error looks like that you get on the MID if you disable your DRL's or if you were to put LED's in as your DRL's. I tried looking for a pic of this, but I can't seem to find it. Does anyone have a pic of this on their TL? I have an 08, but I guess a pic of any year TL that has the DRL light error on would work. Thanks guys!
Old Mar 25, 2012 | 04:34 PM
Steve 21's Avatar
I don't have a picture but all it says is DRL by the gas gauge if I am correct. All you have to do is go under the hood and unplug one of your drl's and see what it looks like. If you look at the gauge at a correct angle you will also see where the cut out for the DRL light is. The MID I am pretty sure doesn't say anything.
Old Mar 25, 2012 | 05:10 PM
RainSupreme's Avatar
MID won't say anything, there is a DRL light below the tach on the 08's, there is also a harness made by I believe iJDM toys that is supposed to eliminate this problem when going to LED DRL's
Old Mar 25, 2012 | 05:32 PM
Registered Member
Hmm, if it's only a little light to look at I may just pull the fuse and see what it looks like. I think I heard about the harness or something similar when going to LED's, but even then it was a hit or miss getting the light to go out for some people.
Old Mar 25, 2012 | 05:39 PM
Steve 21's Avatar
Not quite what you were asking for, but I snapped this photo quickly when I had to go somewhere. It at least shows you where the light is located that would be illuminated if you disconnect your DRLs. Like RainSupreme mentions there is multiple companies that sell harnesses to get rid of it.
Old Mar 25, 2012 | 05:43 PM
Registered Member
Cool, thanks a lot for the pic!
Old Mar 25, 2012 | 05:48 PM
guitarplayer16's Avatar
I can take a pic, but my car's an 04 so the guages looks a little different.
It is illuminated orange.
Mine DRL icon turns on when I start my car and turns off after I disengage the handbrake.
Do you use your handbrake?
And before people ask, I have a Canadian TL so we have DRLs.
Old Mar 25, 2012 | 06:04 PM
Registered Member
Ok, I found the harness you were talking about, but which one do you go with? There are 5 different ones to choose from.
http://store.ijdmtoy.com/LED-Daytime...decoder-01.htm
And I guess these are only used in the instance that you buy LED's? So if you wanted to keep your stock bulbs, but wanted them off and no DRL light on the dash none of these harnesses would work?
Old Mar 25, 2012 | 06:07 PM
Looks like R3 is for the 07/08 Acura TL.
Old Mar 25, 2012 | 06:11 PM
Steve 21's Avatar
Now someone else would have to let you know how to install a switch, but are you trying to install a switch to turn them on and off or something? Or you keeping the stock bulbs as a place holder and just having them always off?
Old Mar 25, 2012 | 06:14 PM
Registered Member
No, I don't use the handbrake in my car because it's an auto Is there some special trick having to do with the hand brake and the light?
Old Mar 25, 2012 | 06:23 PM
I have an auto, but I use the handbrake everytime I park
Whenever you park your car and set the handbrake, the next time you start it up, the DRL will not turn on and hence the DRL icon will show.
As soon as you disengage the handbrake, the DRL turns on, hence the DRL icon will disappear.
Try it out
Old Mar 25, 2012 | 06:31 PM
Registered Member
My original plan was to maybe just pull the fuse so they would be off all the time and then the light would be illuminated on the dash. If there is no fix for that, it's cool, but if there is I could always try.
Second option was to go the whole DRL route and get the correct harness and see if that works.
Most likely I was going to disable the original setup and leave the light on the stay illuminated on the dash since it's not that big of a light and I probably wouldn't even pay attention to it. Now if it was something annoying that would keep popping up on the MID, like when you have low fuel, I wouldn't bother touching the DRL's at all.
Old Mar 25, 2012 | 06:33 PM
Registered Member
Lol, I'm an ass, it says R3 right on the page, for some reason I decided to skip that section.
Old Mar 25, 2012 | 06:36 PM
Registered Member
Try it out
Hmm, I wonder why the car was designed this way?
Old Mar 25, 2012 | 08:15 PM
Old Mar 25, 2012 | 08:41 PM
Registered Member
Cool, thanks for the pic GP16. It's funny, you could just think of it as it is the DRL light is illuminated even though the light is on because there is a problem, lol.
Old Mar 26, 2012 | 01:46 AM
My DRLs don't come on until the parking brake is released but I never had the DRL light come on
Old Mar 26, 2012 | 04:21 AM
paperboy42190's Avatar
i have the harness from ijdmtoy, and i GUARANTEE if you let me install it you will not get an error code. there's no "hit or miss" its just people installing them improperly or not buying the correct harness. its very specific as to which wire to plug into.
Old Mar 26, 2012 | 07:21 AM
Registered Member
Ah, good info. Too bad I live in NJ and you are in CA, lol.
DerrickW
Nov 15, 2015 05:52 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
phillyguerrilla
Sep 26, 2015 11:27 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
