Metallic tinted windows and navi
I read it in the manual stating that I shouldn't use metallic windows tint on the rear window as it might block the GPS signal. Has anyone with navi experience this problem? I was thinking about getting my windows tinted with metallic film. Any info would be appreciate it. Thanks.
Cesspool of Knowledge
It's possible. If the GPS antenna is part of the wire grid on the back window, you may have problems with this - especially if your window film has a low resistance (ohms/square inch). Even though the antenna elements physically are above the film, having a thin sheet of metal underneath it could have an effect.
PC-Card
Originally posted by Jss1
Llumar titanium works fine. The metal doesn't interact. Before and after pics in my gallery.
Thanks for your help. I checked your gallery and noticed that you have special dignosis screen on your navi. I'm assuming that's PC-Card upgrade. Where did you get that? It looks really nice. Thanks.
P.S. I especially liked the picture of mud guards at work
Moderator Alumnus
Re: PC-Card
Originally posted by dtchung
Hi,
Hi,
Hold Navi Map+Menu+Cancel for a few seconds, the screen will pop up.
Moderator Alumnus
I'm also confused to that message about the tint windows. Where is exactly the GPS antenna? Thanks.
Originally posted by ndabunka
Navi not effected by my Llumar Stealth metallic. I think our GPS antennas are located in the "nub" above the window anyway, right?
Manual states that metallic tint might weaken or block GPS signal. I just wanted to be sure. Thanks all for helpful info.!
