Memory seat switch problem
I have a problem with my memory seat switch. They do not function. The backlights turn on with the other lights, however the buttons dont function. When pressed they don't beep nor do the LEDs in them light up. Any idea what it could be? What fuse controls that switch so i can see if its blown?
it's me, Alan Rickman.
if you push them while the car is on i believe they will not do anything; ie while moving you can program them but you cannot have them move.
Press memo then press one or two - if the LED turns on they might be ok..
All About Trance
Is your parking brake up or down when you're pressing this? If it's down, your memory button will not remember your setting.
Registered User
Originally Posted by RSA_Secure
what exactly do you mean by "Only the backlight works"
when he turns his headlights on the lighting aka blacklighting works.
I have the same problem with my memory, it always forgets. Is there somewhere i can obtain this memory module for a cheaper cost? How much does it cost with acura if i get if fixed?
rockyboy
08-04-2024 10:35 AM
HeloDown
09-08-2015 06:51 PM
