Manual tranny fluid change
MT 2006 computer says i need A13 service, so i took it to Firestone where I do my oil changes, but they said "you don't need a transmission fluid flush on a manual transmission." don't knock Firestone -- they offer a great price on oil changes (with semi-synthetic as their basic service) and i've always had good luck with them.
so anyway, i check the owners manual and see that we're supposed to refill with Honda MT Fluid. i ask Firestone if they'll switch it out if I buy the Honda MTF, but they say no.
my question is should i go buy some Honda MTF or GM synchromesh, and where should I get my fluid changed? not going to do it myself, and not planning to pay my acura dealer $220 for the service. shouldn't any oil change kind of place (ex lub, jiffy, etc.) be able to do this?
you would think so but...
Ck the DIY Garage section so you know whats involced- then look in the phone book for a smaller shop that does hondas-acuras listed in the ad
Its a fairly normal drain and refill of MT fluid, a drain, a fill, and a sight glass for the level,
no flushing involved (thats an a/t issue)
acura will do whatever you request of them- not the full service- just a trans fluid change- no problem
yes, i know it's pretty simple -- i was surprised firestone wouldn't touch it.
i'm sure i can find someone to do it at a better price than the dealer is charging, but i gather i need to buy the correct fluid and take it in since shops will likely not have the right kind in stock?
is there a good source for the proprietary honda stuff?
might call the honda dealer across the st. from acura to see what they say.
$10.28 for GM here:
http://paceperformance.com/index.asp...D&ProdID=41510
then i just need to find someone to change it out...
$10.28 for GM here:
Registered Member
$10.28 for GM here:
$10.28 for GM here:
That's a great price, about $7 less than what a Chevy dealer charges. You'll need three quarts. Your transmission takes 2.3 quarts on a drain and fill (that's 2 quarts, 10 ounces). It is best if you can do this yourself. But if you are not of a mind to do this, find a reliable shop that is familiar with your car and its transmission. DON'T use a quicklube type of service.
Registered Member
He's got a manual so the 3x3 drain and fill is not suggested. However, if his fluid is really cruddy, this would be fine. But with a manual, other than synchronizer shavings and some other like debris, there is no sludge or acid buildup to worry about.
One on the right for me
Just go with a shop that you are comfortable with. If you know someone at a jiffy lube or other type shop, and trust them, then that is fine.
ok, thanks everyone. i ordered my SynchoMesh and found a shop who will put it in for a not-too-unreasonable fee. he stocks Honda MTF, but for $20 more i'll go with the GM per the recs here.
i was wrong about the acura dealer -- it's $220 for AT, but "only" $135 for the MT change. honda dealer wouldn't touch it at all. i called another shop, and the guy said he's just fill it with 10w30. i said, i'll bring in the fluid. no, he says, he has some kind of pump to put the fluid in, and he can't use a different fluid.
what a headache, but eventually i found someone very reasonable who said, "what's the big deal? sure i can do it..."
it's a car-drive it
KoolKatz..
Quick question, just changed my 6spd tranny oil to Amsoil but I put more than 3qts 1/2 I dunno will this be a problem? And where the HEEZAY is the Dipstick for the manual tranny to check? I haved less than 60k and fluid was very clear and clean when drained. Hope I didn't screw anything up. TIA
Registered Member
To set the fluid to the right level, you simply remove the check bolt and let the excess fluid dribble out into an oil pan. When the oil stops running in a steady stream, then the level is good to good. I'm pretty sure you need to remove the splash pan under the car to let the fluid run out...
The check bolt is very small and soft, so be sure to use the recommended torque when reinstalling it. If you torque this bolt off, you will be in a world of hurt.
http://www.acurapartswarehouse.com/o...igPicture=True
KoolKatz..
Thanks fellas! My dumbass was waiting for it to spillout of the (fillbolt) lol. It's soo hot now, can I leave excess oil in there till the weekend? Will I damage anything? Will it start leaking etc. If not I do it later...thanks for such quick replys fellas.
and thanks 94eg!!
and thanks 94eg!!
Registered Member
Good question. I did mine at 15,500 miles and will probably do it about every 40,000 miles thereafter (last time was around 55,000 miles). I would imagine you might want to do your first drain and fill perhaps between 6-10,000 miles since that is when you will get the bulk of the synchronizer filing debris as they wear in.
I don't know the answer to this but I can guess. The Amsoil likely has the better base oil. This can make a difference in cold shifting quality. The amount of FM is likely why the GM fluid cures the 3rd gear shifting issues. Amsoil's FM amount is unknown so it may or may not help with the 3rd gear shifting issue. More than likely it's going to give positive results.
i am so smart S M R T
We know the GM fluid works. I *think* the Amsoil will do well. If money were no object I would start with the Amsoil to try and take advantage if it's better base oil and if that doesn't work, swap it for the GM stuff. I know this doesn't help at all.
Registered Member
I can attest to no cold weather problems when using GMSFM fluid. But my case may not be that solid since I keep my car in my garage when not in use. However, when I was working, I did park under cover so cold days were even colder because no sun reached my spot. I never experienced sluggish shifting in the cold, and that includes temperatures into the teens.
The GM Synchromesh FM does work great if you have occasional shifting difficulties. It cured a third gear issue in my wife's Honda Element after a dealership rebuild. I've been loving it ever since...
I remember there were a few threads a while ago saying the stuff was being discontinued. Is that no longer the case? Has anybody had difficulty finding GM Synchromesh FM lately?
Head a da Family
$10.28 for GM here:
$10.28 for GM here:
In case anybody is wondering, you can get the Honda/Acura MTF for $4.99/qt if you shop online. I use this link to get part numbers and shop at other online dealers as well. Honda MTF part number is 08798-9031:
http://www.hondapartsdeals.com/advan...=fluid&x=0&y=0
Here's another link for GM Synchromesh FM 12377916 at $9.80/qt (they want $8.50 shipping for 3 qts to my house):
http://www.gmpartsgiant.com/parts/gm...-12377916.html
AZ Community Team
94eg! thanks for the info. I had previously used the original and improved Honda MTF's and had notchyness in 3rd that spread to 5th, 6th and 1st in the last year despite changing the MTF at 15-20K miles.
I order three quarts of the GM Synchromesh, changhed the MTF in my 2005 TL and within a few miles was shifting much better. Now I wonder why I waited 5 years
mada51589
05-03-2022 08:54 PM
mugen_kid
11-13-2015 10:38 PM
HeloDown
09-08-2015 06:51 PM
