Manual Scan Request: Rear rotor adjustment/replacement
Hey could someone with the service manual scan the pages covering adjusting the inner rear parking brake for when new rotors are installed. IF you could scan to whole rear brake replacement section that would be even better. It seems mine a rubbing due to the added thickness and I need to adjust them back but a not sure how. Maybe someone could email me the manual if that's possible
Thanks guys!
Thanks guys!
Hey, could someone who needs this check the 3G Garage first?
Hint: CTRL/F, type in the word brake, hit find or next or whatever, depending on your browser.
If there is anything missing, ask for the specific item you need.
I went over the ones that are posted in the garage again, but I don't see what I'm looking for.
There should be a part that outlines how to adjust the parking brake assembly (shoes) that's inside the rear rotors. I'm replacing the rotors today and need to dial the parking brake back so they will fit properly inside the new rotors without excessive rubbing.
I had posted the scans in a thread, but it wasn't in the 3G Garage. I have added the scans to the thread in the garage so it's all in one place. I hope that's what you need because I don't think there is much more, but let me know.
https://acurazine.com/forums/showthread.php?t=118283
asahrts
09-04-2015 05:55 PM
