Maintenance can someone point me in the right direction
Old 05-17-2011, 10:46 PM
murph145's Avatar
Trying to figure out what maintenance i need to do on my car but don't really come up with any thing using the search button...
if there is a thread out there listing maintenance routines at mileage intervals that would be appreciated!
I have a little over 80K miles onmy TL and haven't done anything other than normal oil changes I know I have been neglecting i just drive a lot! want to get the services needed done before i run into any probs due to lack of maintenance.
Thanks for any help!
Old 05-17-2011, 10:50 PM
mrlal8's Avatar
if ur an auto
do a 3x3 atf flush with redline racing
Old 05-17-2011, 10:51 PM
Registered TL Lover
RJANACONDA's Avatar
well pretty much use the mid to tell you what you need to do but the mid dosent tell you about your brake fluid i belive its change after first 3 years then once a year after that some one correct me if i am wrong
Old 05-17-2011, 10:55 PM
murph145's Avatar
Originally Posted by mrlal8
if ur an auto
whats a 3x3 flush i mean i understand changing tranny fluid and yes i am an auto im sure i should have done this some miles ago.
does brake fluid break down im assuming? i guess it is time for this too lol
thanks guys!
Old 05-17-2011, 11:49 PM
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
Change both air filters (cabin and engine) every 30K miles
Change the Brake fluid every 24 months
Change Auto Transmission Fluid every 30K miles
Change timing belt and associated parts at 105K miles
Change coolant every 7 years or 100K
that's all I can come up with off the top of my head...
Old 05-18-2011, 07:32 AM
LoveMyTL-S's Avatar
How about tire rotation?
Old 05-18-2011, 07:54 AM
VQPower37's Avatar
tire rotation at every oil change
Old 05-18-2011, 08:24 AM
mau108's Avatar
Look in the owners manual but if you have an auto don't follow the maintenance interval for the transmission fluid from the manual. Search here for that.
Old 05-18-2011, 02:32 PM
murph145's Avatar
thanks seems pretty straight forward! i called the local acura dealership im going to take the car in get the tranny fluid changed, the brake fluid and the cabin filter he said they will check everything else while it is in... like a dentist go in for a cleaning and come out with 2 cavities filled lol bait and switch
might look a lil funky with a staggered set up but i will take the tires back to discount tires every 6 months and pay the $20 bucks a tire to have them break off the tires from the rims and have them switched... only way i can rotate my tires being staggered and directional tires
thanks same as above
i did find my owners manual and checked it out... when do we need to replace timing belts? it said 60K miles if driven on mountains and what not but what about normal driving maybe 100K miles?
Old 05-18-2011, 02:55 PM
DUHockey9's Avatar
You may want to search for AT fluids. Honda Fluid is garbage and almost everyone here runs something else. Most people run Redline Racing. Honda won't do that for you though.
Old 05-18-2011, 02:57 PM
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
i had made a list for myself from the service manual....
PART------------------INTERVAL
ENGINE FLUID----------7,500
TRANNY FLUID---------60,000
PS FLUID--------------30,000
BRAKE FLUID-----------30,000
COOLANT--------------60,000
SPARK PLUGS----------60,000
TIMING BELT/WATER PUMP--105,000
ENGINE OIL FILTER-------7,500
CABIN FILTER------------30,000
AIR FILTER---------------30,000
TRANNY FILTER----------60,000
TRANSMISSION SENSOR--60,000
WIPERS----------when required
BRAKE PADS------when required
BRAKE ROTORS---when required
MAG BOLTS-------when required
150 POINT INSPECTION----105,000
ALIGNMENTAND TIRE ROTATION/BALANCING----7,500
Old 05-18-2011, 03:01 PM
swoosh's Avatar
again i do all my stuff at home....she is at 150K miles and sitting pretty
:knockonwood:
tranny flush is doing a drain and refill 3 times....since every drain you get 3 quarts out its called 3x3....you do this to get the full fluid out....you will go through 12 qts of fluid in the process...
again i wouldnt recommend switching the tranny fluid from stock z1 to the redline racing ATF all in 1 go....do a drain and refill and see how the tranny reacts...if alls good do another drain and refill in the next 1000 miles....
so in 4K miles you will redline racing in your system and you should be good to go....
Old 05-18-2011, 03:03 PM
myron's Avatar
Old 05-18-2011, 03:47 PM
swoosh's Avatar
yup....i get the car aligned every time i do an oil change....i have the firestone lifetime alignment....plus i know the folks were there....so rotation+balancing is also take care off
i used to take alignment and rotation for granted....my falken zeix 912 lasted me 16000 miles before the camber/toe wear drove it bald....my current fuzions have 40K miles and am barely down to 60% of the thread
Old 05-18-2011, 04:00 PM
RAR
leedogg's Avatar
Received 1,286 Likes on 714 Posts
Their new fluid seems to be a big improvement. I'm willing to bet it has less FM now.
OP - change the 3rd, 4th gear pressure sensors now.
Old 05-18-2011, 04:13 PM
myron's Avatar
yea we don't get those luxuries up here where you can get lifetime alignments. There is only a few places that even wanna touch lowered cars. One of them is a honda dealership and I have to pay 60$ every time I get it done. Gonna do it one of these days. It's been a year and a half since last time i did it and I just got new wheels too.
Old 05-18-2011, 04:21 PM
swoosh's Avatar
^^^ sorry about that bro....i think alignment saves a ton a $$$ when it comes to replacing tires....
try an aftermarket shop....i bet they will have some tech who can do it for ya....$60/alignment is insane....
Old 05-18-2011, 04:24 PM
murph145's Avatar
should i do this myself or just have the dealer do it while doing the other maintenance?
what benefit does this cause?
Thanks!
murph145's Avatar
no shops i have been to or called will do my car lifetime because its lowered
Old 05-18-2011, 04:26 PM
[x] FWCC [x]
tones160's Avatar
any DIY for changing 3rd and 4th gear pressure sensors? Or do i have to pay a shop for that?
Old 05-18-2011, 04:53 PM
swoosh's Avatar
Thanks!
i would do it myself...reasons:
1> cheaper...its simple why pay for it
2> dealers use a pump to suck all the fluid out and put the new one in...i would hate the metal shavings from the tranny to be in there even with the new fluid....
3> as i mentioned i would change the fluid every 1K mile to get all the new fluid in (incase am switching)....if am sticking to z1 then i would do a drain refill every time i do an oil change....this will prolong ur tranny's life....
4> read all the above and you wont need another reason LOL
am pretty much slammed....the firestone here was built last year and damn has all new equipments....the old firestones used to take 40 minutes to just get my car on the rack....in the new one the rack is underground....so he drives on it and raises it up to do the needful
there is a DIY....here is the link:
https://acurazine.com/forums/3g-tl-2004-2008-93/110-diy-guide-replacing-3rd-4th-gear-pressure-switch-3g-tl-2004-2006-a-729149/
Old 05-18-2011, 05:04 PM
myron's Avatar
no man no one will give you free life time alignments when they can charge you 60$ or more for them. I go to a dealership because it's the cheapest haha
Old 05-18-2011, 05:18 PM
swoosh's Avatar
lol not free...i ended up paying USD 80+taxes but originally it was $160 + taxes....i got a 50% discount (took the chic out for dinner)....she had a 50% off coupon hidden under the dress
Old 05-18-2011, 06:29 PM
csmeance's Avatar
Can you use a screwdriver without hurting yourself? If yes, save yourself a TON of money and change the filters yourself. You can buy the same honda filters from amazon.com for much less and put it in yourself. The instructions and scans from the factory service manual are posted in the 3G Service Dept.
It should take about 10 minutes for the engine filter and 25-30 for the cabin filter. All you need is a philips head screw driver and that's it!
Old 05-18-2011, 09:15 PM
murph145's Avatar
^ i think im pretty handy lowered my car and put the aspec kit on i think i can figure that out just gota make sometime one of the next comeing weekends
Old 05-19-2011, 10:10 AM
swoosh's Avatar
yeah dude do it urself....they is a DIY for everything on this forum....it will help you save some $$$ for the next mod
Old 05-19-2011, 12:36 PM
csmeance's Avatar
I didn't mean to sound rude in my post but if you lowered your own car changing the filters will be a piece of cake! The DIY's are in the 3G Service Dept. along with tons of photos and even video's!
Old 05-19-2011, 01:11 PM
murph145's Avatar
^ no you werent being rude at all i was being lazy and a pu$$y about doing these maintenance things lol....
i am going to change my own tranny fluid, change the cabin filter, and then swap brake fluid next week....
but when it does come time for timing belt i think i will take it in for that one lol
Old 05-19-2011, 01:18 PM
rockstar143's Avatar
Received 19,916 Likes on 14,458 Posts
Toldja!!!
Happy modding and maintenance...
Get to it!
Old 05-19-2011, 02:14 PM
murph145's Avatar
^ lol yea i know i know...
i already ordered the cabin filter and i will pick up some tranny fluid next week
Old 05-19-2011, 03:07 PM
swoosh's Avatar
yup, you are smart....i did everything on my car....when time came around for timing belt...even thow there was a great DIY, i took it in....
my suggestion would be buying everything outside and taking it in there....for 105K they do:
water pump/timing belt/serpentine belt/spark plugs/tensioner....you can get the kit with everything for like 300ish....do the spark plugs urself....and take it in for the rest....i did that and they charged me $400 for the install...done in $700....
that was a great feeling LOL
Old 05-23-2011, 04:56 PM
[x] FWCC [x]
tones160's Avatar
That was pretty smart man lol, where'd you get all of the parts from?
Old 05-23-2011, 05:01 PM
swoosh's Avatar
there is a group buy that was going on....you can look for the thread and PM them....maybe they can hook u up....
or hit up rockauto or some other authentic car parts website
Old 05-24-2011, 02:34 AM
con5tant's Avatar
where are you guys getting your cabin and intake filters? i could of swore HandA sold them for cheap but they don't anymore...
Old 05-24-2011, 05:56 AM
csmeance's Avatar
cabin filter = Amazon.com, the ATP HA5 carbon filter was 10 dollars last month.
Engine Filter -> WIX brand filter from amazon.com or one of our supporting dealerships!
Old 05-24-2011, 06:35 AM
ggesq's Avatar
Received 2,181 Likes on 1,210 Posts
https://acurazine.com/forums/3g-tl-2004-2008-93/timing-belt-special-still-going-strong-%40-%24299-shipped-819990/
Old 05-24-2011, 08:14 AM
kstanton512's Avatar
I just took mine into the dealer and they did the full used car inspection for 120 bucks. I am new to all this so I wanted to get a good idea of what was going on with my TL. It definitely sucked paying the 120 just for the inspection but they wrote down everything and the cost (dealer cost). They even told me my air filter needed changed even though I just changed it the day before when I got an oil change. They do wash and vacuum your car for you though.
Old 05-24-2011, 11:24 AM
swoosh's Avatar
^^^ that is actually nice....i (plan to) get a 150 point inspection every 100K miles....i got 1 at 100K and am at 150K....so planning for another one in the next 50K miles....
they did the inspection and greased all the area that needed some lube....
Old 05-24-2011, 11:25 AM
swoosh's Avatar
either amazon or rockauto....i prefer rockauto since it gives me options....amazon is generally 2-3$ cheaper as their shipping is free most of the times
Old 05-24-2011, 04:11 PM
murph145's Avatar
cabin air filter took all of 10 minutes to change and only cost $20 from oemacuraparts.com so saved me $70 on that note compared to what the dealer wanted.... tranny oil i will change this weekend... then next weekend swap brake fluid
Quick Reply: Maintenance can someone point me in the right direction
