Maintenance.
Maintenance.
My car has almost 55K on the odometer. I haven't done much as far as maintenance goes, besides the usual oil change. I've gathered a list from reading other threads and I'm wondering if their is anything I missed, that you guys think should be on the list. Any other suggestion are welcome.
I'll be doing another oil change in a few thousand miles so I added that to the list aswell.
Oil change- Red Line 5w30
Royal Purple Oil Filter (10-2867)
3x3 Redline D4 ATF
Cabin Air Filter- ATP HA5
Brake Fluid Flush- Motul 5.1
Coolant Flush
Seafoam
Power steering fluid (not sure if their is a recommended fluid people are using haven't heard of many people changing this)
AEM filter cleaning solution
3x3 Redline D4 ATF
Coolant Flush
Seafoam
honda ps fluid
I would LUBE all the brake parts and ck pads and rotor condition.
since you are going to different trans fluid- a 3x3 actually requires 12 qts to get as much old fluid out as possible- not mix the fluids
seafoam and plugs at 60 is always my suggestion
LIST/RAMEN/WING MAHSTA 짱
08_UA7_Gr33k
02-11-2016 02:17 PM
02tljj
10-12-2015 10:39 AM
08_UA7_Gr33k
09-27-2015 01:56 PM
