Maintenance.
Old Jun 2, 2010 | 09:58 AM
nate_0022's Avatar
Land of 10,000 lakes
Maintenance.
My car has almost 55K on the odometer. I haven't done much as far as maintenance goes, besides the usual oil change. I've gathered a list from reading other threads and I'm wondering if their is anything I missed, that you guys think should be on the list. Any other suggestion are welcome.
I'll be doing another oil change in a few thousand miles so I added that to the list aswell.
Oil change- Red Line 5w30
Royal Purple Oil Filter (10-2867)
3x3 Redline D4 ATF
Cabin Air Filter- ATP HA5
Brake Fluid Flush- Motul 5.1
Coolant Flush
Seafoam
Power steering fluid (not sure if their is a recommended fluid people are using haven't heard of many people changing this)
AEM filter cleaning solution
Old Jun 2, 2010 | 10:28 AM
LoveMyTL-S's Avatar
Brake pads?
Old Jun 2, 2010 | 10:34 AM
nate_0022's Avatar
Good call. Completely forgot brake pads.
Old Jun 2, 2010 | 10:38 AM
LoveMyTL-S's Avatar
Yea, when you mentioned brake fluid, I was wondering why not pads or rotors? I think most people would have tought of pads before fluid. LOL
Old Jun 2, 2010 | 10:57 AM
01tl4tl's Avatar
honda ps fluid
I would LUBE all the brake parts and ck pads and rotor condition.
since you are going to different trans fluid- a 3x3 actually requires 12 qts to get as much old fluid out as possible- not mix the fluids
Old Jun 2, 2010 | 12:21 PM
leedogg's Avatar
RAR
possibly spark plugs
Old Jun 2, 2010 | 03:25 PM
01tl4tl's Avatar
seafoam and plugs at 60 is always my suggestion
Old Jun 2, 2010 | 04:55 PM
klatulip's Avatar
3rd and 4th gear AT pressure sensors
Old Jun 2, 2010 | 05:30 PM
cjj2d's Avatar
are the AT pressure sensors an easy change out?
Old Jun 2, 2010 | 05:53 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Might as well replace the engine air filter.
Old Jun 2, 2010 | 05:54 PM
Here you go:
https://acurazine.com/forums/3g-tl-2004-2008-93/110-diy-guide-replacing-3rd-4th-gear-pressure-switch-3g-tl-2004-2006-a-729149/
Old Jun 2, 2010 | 09:28 PM
nate_0022's Avatar
I thought you didn't have to do the AT preassure sensors on the 07-08 tranny?
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
copmagnet82
3G MDX (2014-2020)
71
Nov 5, 2015 08:29 PM
02tljj
Oct 12, 2015 10:39 AM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
