Lube for tacky door seals?
I think some of the noise I get from the "B" piilar is from the rubbber door gaskets which have gotten tacky from humidity. I tried silicone spray which made it worse. Any recommendations for a lube. I have some general purpose lithium grease. But I would like to try a dry lube. Thanks Tim
an Acura has-been
BMW has a door seal lube designed for the rubber used.
Not sure if it will work on the TL, but worth a try, just be carefull on the silicone, I have heard that it is not the best for the rubber seals.
It appears that the 5 series of old (prior to the bangle butt version) had this very problem, and BMW in thier wisdom, made a profit on this problem by selling door seal lube.
I understand it is available at BMW dealers nation wide for around $13 and lasts about 6 months, so you can do this when you condition your leather seats.
One more thing to do
einszett Gummi Pflege Stift. Same stuff that BMW uses. Works well. hope this link works.
http://www.detailersparadise.com/_Sy...ductDetail.asp
ATB,
Tom
ATB,
Tom
soupi
14
11-15-2015 11:15 AM
