Low in the snow.
Low in the snow.
Twill be my first winter driving a lowered car (~2.5") and driving a manual car. It's difficult enough in the summer avoiding pot holes, road obstructions, curbs, etc. Do you guys that live in snowy climates dread driving in the winter?
That's too much work! Maybe if I was on coils.
I realllllllly need to have an exhaust shop adjust the exhaust flange where it meets the catback. That's my lowest point. I could see some big problems with that in the winter.
The LSD should be a big help this winter!
Quality winter tires will make the biggest difference. Also if there's any snow on the ground I usually launch in 2nd gear or you'll just be spinning tires. Being low won't make too much of a difference but just be careful of what's on the roads, you don't want to hit ice, snow bank or winter road debris and rip off your front bumper! (happened to me)
I drove an Accord that was lowered a fair bit for several years, and this area can get quite a bit of snow. The first two years I raised it up for winter, but eventually I gave up, left the lip on and drove it at the same height year round. The last year I lowered it more and it wasn't a problem, but I don't see any winter pics from then. This was on 'high performance' summer tires that were typically balding by winter, and replaced in summer. If the snow was deep enough, it would rub on the underbody, especially in the rear, and cause the rear to be really loose. Usually not a big deal. However, USUALLY the streets get cleared fairly quickly so the typical inch or two is totally fine. I drove it daily, typically 50-80 miles.
That said, my TL is a bit more picky in the snow. The LSD makes things a bit complicated unless you want to go straight. The manual isn't a big problem, except I have stalled the vehicle once or twice with the pedal to the floor. Apparently the traction can be a bit aggressive under some conditions. Usually it works great and I leave it on. If you stop on an incline with a manual, turn it off.
The button I turn off when there is snow...I learned that quick last winter
The 6 speed your better off with, than an auto. You can control the gear/rpm's easier- obvi
The lowering may screw you up in the deep stuff
Tires are your best friend though. Perhaps consider a winter wheel set up. Much cheaper than another car/insurance.
Howcome it doesn't snow here?! Over here we're lucky if it rains. Also when it does rain everyone gets all scared because they aren't used to driving in anything but sunny dry weather
Knowing how to drive in the snow also helps. Have to write my late husband was great at it even without snow tires. Ice is not a good thing. We lived in the Pocono mountains for 11 years.
I'm on HR Sport Springs for a base TL, Koni Yellow Shocks on the lowest perch, and 255/40 tires. Between the combination of the three, I'm dropped about 2.5".
My point is winter driving and the type of car used plays a significant roll in terms of handling and confidence.
My current winter tires are cooper weathermaster st/2's (if you Google for it you will see my 2videos in real life testing scenarios)
For what it's worth I drove a Ford Taurus (FWD/96 year flavor) for many years and drove in many winters.. Never needed snow tires in any of them and I had 100% confidence on the road. In the TL+winter - it was a serious turd..
Make sure you get 225/235's if and when you buy snow tires. Less rubber contact to the road is king!
Check Craigslist, but bring your guns and friends with guns! I've seen sets going for 200bux on a consistent basis.. You want to look for the people who just sold their car's and need to get rid of their 2nd set of tires.
I just bought a brand new set of blizzak ws70's 235/45/17's off craigslist. They have 11/32nds tread left so basically new 12/32nds is new. I payed $300 for them, if you sort through the crazies there will be some good deals on there.
I used to plow snow in my accord and civic, they were pretty much never raised up for winter and without winter tires. My TL last year was only raised up to where there was no wheel gap, no traction whatsoever without the winter tires, did fine plowing through snow with a good set of winter tires after though, only had 2 front only too and got them for $80 off Craigslist. Also as long as your alignment is good, you should be fine.
I considered winter wheels and tires for my 07 6mt Type S, but I just ended up buying a $5,000 dollar grand cherokee overland. Thing is super comfy, tons if power from the 4.7 HO engine, and has a surprising amount of luxury options. I almost can't wait to try it out in the snow. The TL will get to stay all cozy indoors.
I was kinda hoping ebelp would have chimed in this thread since hes so low and in upstate NY lol.
We don't get much snow here so I've never had a problem. But I dread driving my car in the snow if its 1" or 10."
