Lost climate control and display of climate and radio
Ok this is what happened.
I have an 08 TL non nav. But front frame bent. Found 06 body and had Aspec. Body kit picked up dirt cheap. It had Nav. But like normal check disc got 3 dvd units and still same problem so went tablet conversion in 06 have all working but the body is in alot of rough shape had to calculate fix 08 or 06 had to go 08 including reading about the hondata threads. So how to get my tablet in the 08 saw that one guy moved the display down to shifter I liked the idea so I did it cut the wires and made longer. Yes battery was off the first time. Stupid me had to move the car and forgot about wires being to close to each other. And now the display don't work and the climate control is on high with no control. The displays 2 of them work I thought I fired it and bought another. How I found out that both work is the threads of 05 to 08 conversion they work in the 06 but nothing in the 08 I have swapped fuse boxes cabin and engine CCM with both got 08 fuse box and temp sensor module today and blower resistor and nothing has changed. Can someone help me with wat did I Fri in my 08?
