Looking to purchase VLEDS bulb HELP Needed!
Looking to purchase some drls and leds from vleds. I am a complete noob in Headlights.
I have 04-06 Headlights.
And I am looking for a Amber/ White / White setup. Can't find pic But similar to this.
Just trying to find out if I have to buy $200 harness for every bulb I buy. Any help appreciated. Again I am a NOOB
Switchbacks - VLEDs Triton V3 7443 - Plug and Play
Lower Fogs - Just get HIDs or "frosty" LEDs H8 - Plug and play if LEDs, use relay harness if you're using HIDs (it's like 10$ for the harness or buy a HID kit that includes a harness).
Frosty LEDs: https://acurazine.com/forums/third-g...s-hids-915743/
If you want to buy LEDs from VLEDs:
This is their selection - http://www.vleds.com/shop-bulb-numbe...s.html?cat=696
DRL - Do the independent fog light mod, and just get bulbs - no harness needed.
https://acurazine.com/forums/third-g...switch-772633/
The harness is only needed if you have factory DRL so you won't get an error, and get full power.
Looks like VLEDs doesn't sell amber 9006 bulbs, so you'll need to go somewhere else.
Thanks GP Very helpful. Might do the frosty's for the fogs... Looks like I missed the boat on vleds del amber. I really liked how they looked.
Can't attest to the quality but...
http://www.ebay.com/itm/TWO-Amber-Orange-50W-High-Power-10x-Cree-XP-E-9006-9012-HB4-Fog-Lights-bulbs-/310821695200?pt=Motors_Car_Truck_Parts_Accessories &hash=item485e6aaee0&vxp=mtr
Two Amber Orange 50W High Power 10x CREE XP E 9006 9012 HB4 Fog Lights Bulbs | eBay
What's the best LED harness to get?
This is their selection - VLEDS
This is the setup I came up with so Far...
Turn Signal- VLEDs Triton V3 7443; Comes with all the hardware?
5K WHITE AMBER SWITCHBACK V3 TRITON LED SYSTEM | 1 PAIR - 7443 - 7440 LED - Shop Bulb #
Upper Fogs- Amber Led might not be drl. So according to what you said just Plug in.
Lower Fogs- Frosty's h8 leds . Just plug in.
What is the middle light between the upper fog and turn signal? Told you I was a noob
Yup, your upper fogs are just plug in, since they are not actually "DRL".
Lower fogs is plug in, also.
No harness is needed for your car
Sweet, Just wanna know. Bulb # for low beams, according to this thread it would be Hid main beam?
And Any led is Plug and play?
Thank for all the help!
https://acurazine.com/forums/third-g.../#post10075217
Your fog lights in your headlights..
"Fogs for 04-06 models use 9006 bulbs"
Your low beams and your high beams are projected from the HID housing in the outer most projectors of your headlights. That D2S bulb is an HID (High Intensity Discharge) bulb. There is a flap in that projector to allow more (high beam) or less (low beam) light through. You don't want to mess with trying to put an LED there.
So in your headlights from outside to inside, running/turnsignals lights (you're about to put the triton v3's there), then your headlights (high beam/low beam D2S HID's), then your upper fogs.
ijdmtoy is junk.
As far as brighter D2S hid bulbs I recommend osram cool blue intense. They are rated 5500K whereas factory D2S bulbs are 4300K. They will be more white and more bright (more lumen output)
Check them out at www.TheRetrofitSource.com
9005 daytime running lights in the center compared to fog lights for the 04-06 lights.
And yeah osram CBI are 5000K. No clue why I said 5500K
Ended up buying these leds for the 9005 drl. Are these plug and play since they are leds going into the drl socket?
http://www.ebay.com/itm/2x-9005-SUPER-AMBER-102-SMD-LED-Fog-Light-Lamp-Daytime-Running-Driving/271393416008?_trksid=p2045573.c100033.m2042&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20131017132637%26meid%3D9694cec9732745568762bd3d93033135%26pid%3D100033%26prg%3D20131017132637%26rk%3D1%26rkt%3D4%26mehot%3Dlo%26sd%3D271393416008
2X 9005 Super Amber 102 SMD LED Fog Light Lamp Daytime Running Driving | eBay
And your right about the order of the lights. When I said "center" I was thinking about starting from the lights near the center of the car next to the front grill. Sorry for the confusion
Can you recommend a good harness?
Nope you'll need a relay harness. DRL socket supplies bulbs with 6v whereas those LEDs need 12v+ to illuminate
wow, you're all over the map.
The Retrofit Source Inc is where you should GET ALL YOUR HID and lighting needs....
they sell great relay harnesses.
No, you don't need a harness. vietx thinks you have a DRL socket on your 2004 TL.
Factory 07/08 need one because it has a DRL socket which only provides 6V.
Your 04-06 upper fog connector is already 12V, but it is 9006.
Swap the connector to 9005 and do the independent fog mod.
he's all over the place.
Yeah, he really is
All he has to do is cut the 9006 connector off, and wire it to a 9005 connector to fit the DRL bulb slot in the new headlight.
As far as power, that "9006 socket converted to 9005" will still be 12V.
I didnt realize that the power source will still be the same.
Carry on, all mighty GP16
You can read my two earlier posts, or you can do this:
DIY: Convert 9005 bulb to fit 9006 harness. Increase visibility! - 8th Generation Honda Civic Forum
Are the switchbacks annoying to other drivers?
I'm thinking about taking advantage of their Cyber Monday sale, but I was wondering if the V3 Triton Switchbacks would be annoying to other drivers when lit white in the front turn signals behind USR diffusers. Has anyone looked at what their switchbacks look like at night when lit white, while sitting in another car? Please tell me they don't cause glare to oncoming drivers so that I can get them now.
