Looking for part
Old Aug 7, 2012 | 07:43 PM
Rowan52's Avatar
Looking for part
Hey guys I was in an accident a while back and a little damage was done to the side of my car. I was wondering if this is a part I can buy and easily replace or am I better off just trying to have it repainted? I thought I found it at one point but when I tried looking again I didnt have any luck.
Old Aug 7, 2012 | 08:00 PM
sauceja's Avatar
Desert Life Sucks!!
I had a coyote hit me in same place a few weeks ago. I did not need to have mine repainted.
But I did have to remove that whole rear section and fix some of the tab holders in order to get the gaps back right.
It took about 10 minutes to remove. Jacked up the rear of the car. Get a stubby phillips screwdriver and a clip remover or your preferred method.
I used super glue to fix the broke tab holders and waited about 4 hours to put everything back together. I was going to use jb weld but the super glue method is holding up great for me so far.
I am not sure if they sell just that part or not.
Good Luck!!!!!
Old Aug 7, 2012 | 09:14 PM
guitarplayer16's Avatar
That would be the sideskirt.
It is easily removable and replaceable.
You can replace it with another rear driver side side skirt (which might be hard to find on its own) or you can replace the sideskirts on both sides to the A-Spec sideskirts.
Old Aug 8, 2012 | 12:33 AM
Will Y.'s Avatar
Registered but harmless
That part was called a "rear rocker molding" by the body shop and comes pre-painted-- mine was scratched up along with the quarter panel. The body shop charged me $58 for that molding back in 2009.
Old Aug 8, 2012 | 01:46 AM
csmeance's Avatar
for your car its: 71950-SEP-A01ZK GARNISH ASSY., L. RR. SIDE SILL *NH700M*
( ALABASTER SILVER METALLIC ) $121.71
here's the link:
http://www.acuraoemparts.com/delray/...All&vinsrch=no
It's prepainted from the factory. You can probably have it repainted for around 60 dollars locally.
Old Aug 8, 2012 | 11:00 AM
Rowan52's Avatar
Thanks a lot that was exactly what I was looking for. Also I didnt realize the a-spec kit would replace that part as well I might just end up doing that instead since I have been wanting to purchase the whole kit.
csmeance
Jan 7, 2026 06:25 PM
handsom-hustla
Nov 13, 2015 05:04 PM
Ny1718
Sep 11, 2015 09:21 AM
hand123
Sep 10, 2015 09:29 AM
hand123
Sep 10, 2015 09:27 AM
