Let's talk ATF....Again
Old Oct 1, 2012 | 09:31 PM
  #41
connork53's Avatar
Originally Posted by i_love_cars
in the time spent on this thread, you could have worked a couple extra hours and made up the money difference and just bought the Redline fluid.
and yes, you are trying to be cheap, don't tell people they are misunderstanding your thread because all you're doing is trying to justify spending less money. There is nothing wrong with that and I don't hold it against you because nobody wants to waste money, but don't try to tell people they're wrong when they are saying you're looking for a justification to be cheap.
That being said, it's a decent fluid. The issue here is how fast the fluid breaks down and how well it handles oxydizing environments. So if you get a cheaper fluid, I would still recommend changing it a bit more frequently than you would the Redline.
you'll be fine.
I'm on salary
And sure it was looking for a way to save money but I was also seeing if it was practical but considering I just went to honda and bought ATF after reading this thread the point was proven that although Valvoline is sufficient the best bet is to go OEM/Redline which I did.
Old Oct 1, 2012 | 10:03 PM
  #42
I hate cars's Avatar
I would go Valvoline over OEM any day. You did the worst of the 3 choices lol. At least the Valvoline would be a DexIII with less FM for less clutch pack wear.
Old Oct 2, 2012 | 03:20 PM
  #43
connork53's Avatar
you'll be fine.
To bad I am on salary huh asshole?
Just went ahead swapped in some OEM fluid very easy job and I actually ended up draining more than 3qts almost 4 actually good thing I bought an extra one just in case
Old Oct 3, 2012 | 07:35 AM
  #44
johnny3's Avatar
OP, I think you did the right thing staying with OEM fluid (Honda).
I have 130k miles on my 05 TL daily driver with a fluid change around each 30k miles or so & never had a trans. issue of any kind.
Old Oct 6, 2012 | 08:34 PM
  #45
connork53's Avatar
That's what I'm hoping for man.
My plan is over the next 3 oil changes to do an ATF change as well.
Any clarification on the filter?
Old Oct 6, 2012 | 10:27 PM
  #46
twigglius's Avatar
we live in a simulation
i wouldn't let an ATF fluid that costs $14 for 4 quarts even sit in a bag in my backseat, let alone my transmission case.
If AcuraZine was Facebook I would like this post.
Old Oct 7, 2012 | 02:16 AM
  #47
Fatfrii's Avatar
went to red line...spent 1500 on a used tranny to put in my car....lets look at it this way...even if redline was hands down best option, its not gonna make ur TL run a 10 second 1/4 mile...be safe and stick to honda ATF.
and here comes the hatred
Old Oct 7, 2012 | 09:28 AM
  #48
jbwua6's Avatar
Good thing I stumbled across this thread about ATF.
I bought my 04 this July and I replace the pressure switches and did a Valvoline flush on mine since my tranny was shuddering, and problem was solved.
Of course like most of you stated, these are high class cars, so any high quality maintenance should to done. So to sum everything up, what really is the best fluid to use for day driving?
That's all I use mine for. I have an oil change coming up soon so I wanna do this once and do it right. And do I really have to flush the tranny 3 times, and if so, how long until I do the flush again after those 3 times? I honestly don't mind spending the $100 on fluids because I or want the best of the best. This is no longer the Integra I had. If maintaining a top class car was gonna be an issue and wasn't prepared to do it then I would have kept my Integra, or like someone said earlier, sell the TL and take the bus.
Old Oct 7, 2012 | 09:29 AM
  #49
jbwua6's Avatar
And another question, which may sound silly, but I want to be certain. Can the same fluids be run into a 03 Accord V6? A buddy of mine wants to know.
Old Oct 8, 2012 | 02:54 AM
  #50
connork53's Avatar
All Acuras/Hondas use the same ATF previously Z1, currently DW1 and they can be mixed with eachother.
Like I said and most others said your transmission could go tomorrow or it could last another 150k. If you use Hondas ATF you will be golden in terms of the warranty.
As far as the frequency I wouldn't really do a 3x3 at once but that's just me it seems like alot of work for little gain (flame me) personally I would do a 3x4 meaning 3qt drain and fill for the next 4 oil changes so you know you are doing it on time.
Also be sure to buy 4qts for the change because I ended up draining ~3.5qts.
Good luck and questions let me know.
Old Oct 8, 2012 | 07:07 AM
  #51
Hate, no, I don't hate ignorance. Your high mileage trans let go many thousands of miles after the installation of Redline. You can blame the failure on whatever you want. Maybe it was the brand of gas or the engine oil.
Old Oct 8, 2012 | 07:10 AM
  #52
There are some good atf threads out there. This is not one of them. Search some more for your own good. Don't run the factory fluid if you want the least wear under any circumstance.
Old Oct 9, 2012 | 12:17 AM
  #53
Legitka9's Avatar
Legit Member
ATF Z1 has been discontinued and yes the DW-1 fluid is supposed to replace the Z1 fluid and be compatible with it but it is much lower in terms of viscosity. I ran dw-1 for about 15,000 miles and decided to get it out of there. I have done 3 drain and fills with eneos Eco-ATF and it gave me peace of mind.
Think about it this way, Honda and Acura builds fantastic cars but realistically the dw1 fluid is meant for the newer line of Hondas/acuras running lower viscosity oils and trans fluids to get better gas mileage. Sure dw1 will work in our 3G's but it most certainly can not be the best for it as it was not designed for the vehicle. IMO it will shorten the life of our transmissions. Run redline, castrol, amsoil, eneos but dw1 is just risky.
I'm no rocket scientist but my 3G has 275,000 miles and counting, still going strong and it's my daily driver!!!!
Eneos goes for about $13 a quart and you can buy it at most napa stores.
Old Nov 3, 2012 | 06:13 PM
  #54
TrustinHFDJ's Avatar
Series Motor's
I think we understand your point, but since your doing it yourself; you are saving money. So in regards to that, f paying the stealership, pay extra for the superior product. That's pretty much how it goes in my mind any time I do anything myself it will be the most premium, expensive, and longest lasting even if I do maintain frequent changes.
I dont know about you guys but I bought my car brand new, and I plan to keep it that way! Maybe that is where the love is generated.
Old Nov 4, 2012 | 03:21 AM
  #55
TheBumbino's Avatar
Most of us probably don't need Redline Racing ATF in our TLs as a DD but I have it in mine because it gives me a little peace of mind that my transmission fluid is actually helping to prevent damage. Just from what I have seen and heard on here about Z1 I don't want to be anywhere near it.
Old Nov 4, 2012 | 03:58 AM
  #56
TheChamp531's Avatar
Chapter Leader (San Antonio)
This thread is just... sad.
Old Feb 26, 2016 | 09:56 AM
  #57
Freddyceemore's Avatar
So what was the ratio when doi g your first drain ?? I jus got my tl and want to use redline/oem
Originally Posted by connork53
I'm on salary
Old Feb 26, 2016 | 11:25 AM
  #58
musiclevelz5's Avatar
No matter what fluid or combination you decide, the transmission will still fail no matter what you do.
The best thing you can do to extend transmission life is do your drain and fills more frequently.
Old Mar 2, 2016 | 01:50 AM
  #59
marxw13's Avatar
Alright so I know theres a million ATF/oil debates and threads here I've read them trust me.
Here's my statement for everyday driving there is no reason for me to use redline ATF nor is there a reason for me to use dw-1 because its almost $10/quart.
Here's my question -- Has anyone used Valvoline Maxlife ATF it is on sale at autozone here $14/4 quarts it says it can replace z1 which my TL currently has but has anyone used it? I know redline is the best but no I'm not about to pay $100+ for ATF when I can get something good enough for me for $35 right now.
I plan on doing the 3x3 which I've done before on my buddy's car with redline but he also tracks his TL.
I've seen threads about it being used by our 2g friends but nothing more than it being mentioned in the 3g area.
Thoughts/opinions?
I got my 05 base TL over a year ago and did a 3x3 drain and fill on it right away. I used the Valvoline Max Life from Auto zone that you mentioned and I haven't had any issues. Ive put 8,000 miles on the car since then after a cross-country drive to not to mention I live in the inner city and do almost all stop and go driving. I hate to say this but alot of the guys on this site are snoobs and will run you into the ground for not spending top dollar on everything. As for myself, if I had that kind of money I wouldn't be driving an 11 year old car.
Old May 11, 2018 | 06:25 AM
  #60
jaydubz's Avatar
This thread....Unbelievable.
Old May 11, 2018 | 12:00 PM
  #61
stevemk07's Avatar
Max life is the best
Actually its whats in my car now.
Old May 11, 2018 | 12:22 PM
  #62
horseshoez's Avatar
Latent car nut
Max Life is contrary to Honda's recommendation; by definition not the best.
Old May 11, 2018 | 12:27 PM
  #63
TheSauceBoss's Avatar
You mean to tell me that I should stop funneling my used motor oil into my trans as a fluid replacement?
Old May 11, 2018 | 12:35 PM
  #64
horseshoez's Avatar
Latent car nut
If you have an older Honda Accord I4/5-Speed then used motor oil in the tranny is a good option, otherwise not so much.
Old May 11, 2018 | 12:40 PM
  #65
I was just being a smartass but after looking it up, you are indeed right, I guess motor oil in transmissions (for older, manual transmission cars) was relatively common. Learn something new every day!
Old May 11, 2018 | 12:43 PM
  #66
horseshoez's Avatar
Latent car nut
Oh a wiseguy aye? Nyuk-nyuk-nyuk!
Yeah, I got that, but since it rang the bell in my head about the older Honda gearboxes, I thought I'd respond.
Old May 11, 2018 | 01:19 PM
  #67
*Curly blocks eye-poke*
*still gets slapped in the face by Moe*
Old May 11, 2018 | 01:53 PM
  #68
horseshoez's Avatar
Latent car nut
LOL! Thanks for the laugh.
Old May 11, 2018 | 04:05 PM
  #69
pohljm's Avatar
Back in the day we would add a quart or more of tranny fluid into the crankcase and run for a little while without much load before draining for an oil change. The thinking was that there were much more detergents etc in the tranny fluid and this will clean flush the crankcase better
Old May 13, 2018 | 12:04 PM
  #70
truonghthe's Avatar
Lol the reason why people did that because the ATF causing the seals to swell up and reseal any oil leaks, just don't let it run too long or it will blow out the seals.
knight rider
Mar 4, 2016 08:59 AM
jterp7
3G MDX (2014-2020)
Feb 3, 2016 08:34 PM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
thegipper
Sep 28, 2015 01:01 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
