Lemon Law: Need your opinion
Old Nov 18, 2007 | 11:03 PM
noshow_nogo's Avatar
leased the vehicle on Jan 15.
-first service visit was Feb 2 because the car pulled to the right
-second service visit was Mar 26 and I had some free time so went in again for the pulling. All they did both times was inflate my tires up to 40psi all around
-third service visit was Sept 21. Dealership finally accepted the fact that the steering wheel was off center. "adjusted" and then aligned. (how this takes them 4 hours is beyond me)
Now the pulling was never fixed. In fact, after the 3rd service, the service manager told me that it still pulls, but not as much, this is the best we can do. I am 24 yrs of age and don't qualify for a loaner. I work 7 day/70 hour weeks and quite frankly, I don't have the time to waste sitting around the dealership while they inflate my tires. I screamed tire pull each and every time, but they denied it.
I believe this would be grounds for a Lemon Law claim, given I have given them 3 tries to fix it for a prolonged period of time. The alignment of a vehicle is critical especially with the winter season rolling up. I am about to write a letter to the Manufacturer directly abiding by the guidelines of NJ. Has anyone in NJ filed a Lemon Law complaint before and any advice to give to me?
Old Nov 18, 2007 | 11:07 PM
subinf's Avatar
One on the right for me
Read the statute to figure out how many repairs are required for lemon law status. I also believe the law covers amount of days in the shop for repair. Varies from state to state.
Old Nov 18, 2007 | 11:20 PM
NJ statute reads that after 2nd attempt to repair and is not resolved, send a letter to the manufacturer to fix oen last time, then if that doesn't do it, submit appeals to state Lemon Law.
car must be out of comission 20 garage days OR 3 attempts to fix it. I don't know if one takes precedence over the other. in my case it would be 3 attempts to fix and 3 garage days.
Old Nov 19, 2007 | 12:17 AM
subinf's Avatar
It is an either/or situation. I guess it is time for you to send a letter then process your claim under the law. Good luck with everything.
Old Nov 19, 2007 | 12:27 AM
Eoanou's Avatar
'10 Hyundai Genesis Coupe
Yeah, it looks like the statue will have you covered, I'm thinking someone who had the car before you did hit the curb pretty bad, and might have bent the subframe. If the subframe is bent, the car will pull to the direction from where it was hit. I know because a couple people from the forums have actually had this happen to them.
Old Nov 19, 2007 | 03:12 AM
darksom1's Avatar
~Da Nocturnal Cheetah~
This sounds pretty much like an open and shut case, but expect a fight nonetheless. It's just the natural order of things in this market.
Old Nov 19, 2007 | 04:14 AM
subinf's Avatar
Also need to see if law covers leases
Old Nov 19, 2007 | 09:02 AM
jtkoo7's Avatar
Did they tell you, that you don't qualify for a loaner or are you assuming that?
Old Nov 19, 2007 | 09:03 AM
KJSmitty's Avatar
WDP Director of R & D
If the alignment is in spec, then it's in spec. If the dealership wont, just swap the front tires, left to right/right to left etc.. If it is a tire/belt issue that will identify it.
Otherwise, if alignment is the only issue take it to an independent shop and have them give you a second opinion. Yes we are all busy and shouldn't have to spend a dime having a car under warranty "repaired". But,,, you will spend allot more time and money "attempting" a lemon law buy-back/replacement etc..
-What brand of tires are on your TL? I would find a 4 wheel alignment shop that sells that brand of tire so if it is the tires, they can assist with a tire /price compensation.
Dealership Service dept's only like to make money - Your problem is no longer allowing them to do that...
So, is it just the alignment or do you not like the car?
Old Nov 19, 2007 | 06:53 PM
would there be a way to test for tire pull??
Turanza EL42, the revised version for the base TL.
I love the car, and they swear the alignment is in check. but if I have to cock the wheel to about 1'oclock when I'm cruising in the highway, regardless of which lane i'm in, something's not adding up.
Old Nov 19, 2007 | 07:50 PM
I was informed that I would not qualify for a loaner. in the state of NJ, I must be at least 25
Old Nov 19, 2007 | 07:52 PM
ggesq's Avatar
http://www.state.nj.us/lps/ca/ocp/lemguide.htm
Old Nov 19, 2007 | 10:52 PM
KJSmitty's Avatar
As mentioned, swap the tires around and see if their is any difference. Start with just moving the front tires.
I had the original EL-42's and they did the same... Not to mention they never could balance them.
You are correct, something is not right if the above is happening. If you let go of the wheel will it attempt to change lanes on you?
Seriously, swap the front tires around and see what happens. Mine was obvious. Threw the EL's away and went with the Michelin Pilot Sport 2's and the car felt like it should have new...
Having a lease and this type of issue would aggravate many of us. The last thing one would want to do is spend money on tires etc.. But you may have to to fix the issue if the dealer refuses. Most of us would agree that the EL-42's are less than adequate for any car...
Good luck - let us know what you find if you play around with tire placement etc.
HOWELLiNC
Wash & Wax
35
Jul 16, 2017 04:13 PM
adrian_s2k
1G RDX (2007-2012)
23
Jan 12, 2016 04:25 PM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
eastcoastguy
Sep 23, 2015 06:29 AM
carz0159
Sep 20, 2015 06:11 PM
