LED's bulbs for DRL's for 2007 TL-S
Old 06-03-2007, 03:44 PM
  #41
Lead Foot
tripflex's Avatar
Yes i'm very interested in this also, maybe i should just give it a shot and see what i come up with :-D
Old 06-25-2007, 11:51 AM
  #42
Let's Go Pens
Evader's Avatar
Originally Posted by Mug
I'd like to turn off my DRLs or send both powers to the fogs. I like DLRs but would also like the fogs on without the headlights. If I switched the power wires on the fogs to the DLRs and the power from the DLRs to the fogs, it would be interesting. I'd have 04-06 fogs and my fogs would be the DLRs. However, I still like the look of the fogs with the headlights. So if I sent both power signals to the fogs, I should have that control. The stock location of the DLRs wouldn't be used at all.
Any Update on this? I would love to be able to have just my fogs on.. I already removed the DRL fuse because the annoyance of piss yellow bulbs was too much to handle.
What i'm looking for is a Brighter (hid looking) bulb for my high beams. I hear someone mentioned certain bulbs are illegal, can you explain this and why? If it's because it's "too bright" I'm fine with that.. I rarely use my highbeams anyway. Also what is the bulb size for our high beams
Just a quick question. I just thought of this now, but is there a seperate bulb for the High Beams or is it actually the same lights as the DRL just when you switch to high beam it comes out at a higher (brighter) current? My wife has the car today so I can't be certain on this one.
Old 06-26-2007, 10:34 PM
  #43
A J35A8 EG civic is in
sunny201's Avatar
Im almost 100% sure that im right on this one. The DRLs are always the same. The projectors are your highbeams and low beams. What happens is there is this thing in the projector that moves which causes the light to shine higher. I know I didnt put it in the right way and I know there is someone who will wind up explaining it better lol. You can actually hear the thing move when you have your windows down and listen towards the headlights while turning high beams on and off.
Old 06-27-2007, 01:01 AM
  #44
'04 6mt Pearl
triggle's Avatar
Disadvantage of all-white DRLs: People will assume you have your brights on since they are located on the inner portion where the brights usually are. I am sure people will be flashing you even if the DRLs are relatively dim. This might not be too much trouble driving during the day but at dusk or dawn you'll likely get flashed. We've had DRLs here for a long time and if they are white the assumption is high beams.
Old 06-27-2007, 01:25 AM
  #45
HID Headlight Guru
linuxglobal's Avatar
only on 04+ TL
The pre 04 have ghetto 9005 high beams.
DRL are ok on highs at low power (50-60%)
I have my DRL off and they turn auto on at like 8 pm LOL.... its so insensitive to light levels on my car.
Most hondas have drl features to warn u when the bulb burns out, thats what my 07 civic does if u replace the bulbs with an led.
these bulbs are way too overpriced and not bright enough, dont use them. Just leave drl stock or get rid of it. You can also keep ur hids on all the time LOL... waste of parts IMO.
Old 06-27-2007, 10:47 AM
  #46
Let's Go Pens
Evader's Avatar
This is when you flash em back and show em your real high beams, lol
Old 03-22-2015, 07:36 PM
  #47
JD TL-S's Avatar
Old Thread-
New Again
Seems like a PITA to replace DRL Bulbs.
Thought is was plug-n-play
Needing resistors
Anything NEW out here ?
Old 03-23-2015, 05:42 AM
  #48
bla8291's Avatar
Replacing DRLs - that's actually the easy part.
You still need a harness and a set of resistors. If you get them from the right place, this will be one package.
The hard part is where put all the cables once you're done.
Old 03-23-2015, 09:19 AM
  #49
Received 8,753 Likes on 6,750 Posts
ACURA HONDA LED DRL HARNESS
Then get some LED DRL's : 10 XB HB3 9005 H10 9145 LED DRL/FOG LIGHT BULBS | 1 PAIR - 9005 HB3 - Shop Bulb #
/endthread
Old 03-23-2015, 07:11 PM
  #50
FamilyGuy's Avatar
Here's the relays, driver's side resistor and the bulk of the wiring, hidden away:
Ran the wire to passenger side using the factory wire harness with zip ties:
Passenger side resistor:
Clean engine bay, only wire visible is the power wire on the battery:
Hard to capture the 5 k light on my cell phone camera, but best i could do for now:
Old
New
kocyk123 (10-05-2015)
Old 10-05-2015, 12:46 PM
  #51
kocyk123's Avatar
Old
New
Awesome! I just purchased exactly the same bulbs and harness and really can't wait for them to arrive...
Old 10-21-2015, 03:17 PM
  #52
warterdesmanne's Avatar
Originally Posted by linuxglobal
do they have fogs now? seems like a waste of 9006 for low wattage DRL.. it eats the bulb alive... thats why they develop that brown crap on them.
Ure talking about the 07 TL_S right>?? otherwise the DRL is on the TL fogs which are in the housing anyways. I guarantee u the 07 TL-s uses the drl bulb at full power for daytime flash to pass since hid is off anyways.
In any case direct swaps will not run the led at 12v thus they will be dimmer than a harness setup. Your idea would work in 05+ max where it uses a 12V (3157 or something) as DRL but its a 21W running at full power.
6V Drl will light up dim.... o well my DRLs are off hahhaha .... and i love it....its one of the dumbest features for cars... for bikes its great..
I have an 07 base and the HID is the day time high beam flash. Not the DRL. The HID has a physical adjust to the lens for high vs low.
Old 10-29-2015, 09:07 PM
  #53
ATLS15's Avatar
Are there any led's that don't need extra harness? Like DDM or something? I don't need my drl's to be bright or anything, I'd just like 'em to be white. I bought Sylvania Silverstar Ultra lamps hoping that it will be any different from OEM bulbs... Yeah right...I can barely see any difference.
Old 11-01-2015, 05:28 PM
  #54
vietxquangstah's Avatar
No.... The DRL bulbs operate on 6 volts. That is what the DRL circuit supplies to the bulbs. That's why any halogen bulb you put in is dim. That's why any led bulb you put in there won't work.
LEDs require 12v minimum to operate.
The relay harness supplies full battery voltage to the DRL which is anywhere from 12-14v
Old 11-05-2015, 10:23 PM
  #55
ATLS15's Avatar
Thanks, it makes more sense now. I'm surprised that led's require more energy than stock bulbs though...
Old 11-05-2015, 10:31 PM
  #56
It's not that they require more energy. DRLs run at 6V because halogen bulbs would just be running at half power/half brightness. LED drivers operate at 12V by default. Steady state diodes and all
Old 11-05-2015, 11:12 PM
  #57
ATLS15's Avatar
I was really hoping that they made led sets that would operate at 6V. The car I had 10 years ago had led's for DRL's, I mean come on 😐
Old 11-06-2015, 07:36 AM
  #58
Lol what car was that
Old 11-06-2015, 08:25 AM
  #59
Registered Bunny
polobunny's Avatar
Received 1,073 Likes on 892 Posts
Yeah I really don't think any car used LED for DRL 10 years ago, lol.
Old 11-06-2015, 11:44 AM
  #60
ATLS15's Avatar
91 Opel Kadett baby! I think those were drl's. I used same LED's we have in our doors.
Old 11-06-2015, 01:16 PM
  #61
Registered Bunny
polobunny's Avatar
That was incandescent, not LEDs.
What modele did you have? Please say GSi 16V. That crazy 2.0L
Old 11-06-2015, 02:35 PM
  #62
ATLS15's Avatar
I'm sure that those were led's because I had the blue ones, and then I installed the white ones to match my HID's.
Haha, it was an 8V
Old 11-06-2015, 02:48 PM
  #63
Registered Bunny
polobunny's Avatar
Haha, it was an 8V
Pfff move along then.
The LCD display was so strange too, it was slow to update and it looked like a kids toy from the early 80ies:
Tomy Turning Turbo Dashboard
Old 11-06-2015, 03:18 PM
  #64
ATLS15's Avatar
Lol. Nailed it
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
Ratheruneeq
09-28-2015 07:41 AM
ripit
09-26-2015 06:19 PM
eastcoastguy
09-23-2015 06:29 AM
Quick Reply: LED's bulbs for DRL's for 2007 TL-S
