Latest mod: Blue underdash lighting
I mounted and wired in a couple blue leds above each floor mats. wired them in with the parking lights. they came out great. just enough light to match the factory leds from the overhead console.
Originally Posted by THTL
nicely done. please give more info.
Originally Posted by lembowski
did you use the little ones with the leads and the plug? did you need resistors?
Registered User
Originally Posted by evnash
no resistors. they are just blue 12v leds with a red and black wire coming off them.
Originally Posted by rbf351
no such LED exists, the most a LED is rated for is usually 3 volts. if they already have leads on them, then you already have a resistor installed
King of NYC
I used to have single LEDs like that in my old Mercedes. Had them in the rear too. The resistors for those LEDs are soldered in-line. Pretty much built in and they run straight off any 12V source with really low draw and resistance. You can literally wire 10LEDs up like that off the same source if you wanted to.
In my TL I used LED strips in those same locations.....you should look into that, looks hott. Gives a great "mood" to the interior and the light is even and not too bright at all, out of the way. Got it wired to a switch to turn off on those long night trips.
Originally Posted by lights
you gotta go all out once you started...
this was 5 years ago....
rockyboy
01-25-2016 06:00 PM
