keyless entry remote programming?
Old Jan 10, 2007 | 02:04 AM
cidviciousone's Avatar
9th Gear
I purchased extra remote for my 04 acura tl and I need to re-program it to my car. Does anyone know how to do this without taking it to the dealer to recognize the user 1 remote?
Old Jan 10, 2007 | 06:39 AM
Ron A's Avatar
Administrator
Welcome to the forums. This thread will help.
https://acurazine.com/forums/showthread.php?t=89492
Old Jan 10, 2007 | 08:38 PM
9th Gear
Thanks bud it actually does work but took me a couple of tries and after i erased my original remote but i got both up and working good info!! The instructions are weird but i figured it out. If anyone is trying to do this you have to leave the ignition on the II position and then push the button at the end. If you hear a actuator working when you press the button that means it worked!! But you do have to do the sequence 3 times within 4 seconds it seems impossible but you can do it!! Turn on ignition to II position and press the lock button then go to the O position and repeat 3 times on the final one leaving it on the II position where the programming should work!! Thanks guys!!!!!!!!!!!!!!!!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jul 16, 2017 07:33 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
