Interior Panel Removal
Anyone know how to remove the interior gray panel that sits next to the driver's right knee? I need to run a wire behind it and can't find any screws. Any help is appreciated (SEE PIC). THANKS!
321 whp SAE
not a hard job.. pull the panel under the steering column.. this will expose the screws on the left side of your target panel.. remove the aluminum trim.. open the glove box and you can get a good grip from there.. there are 2 screws on the bottom of the glove box. under the rubber piece.. pull those.. you only need to pull up the console a bit in order to get your target panel out.. under the aluminum trim there are a few screws to remove.. shouldn't take long..
Oakes
Wash & Wax
10-12-2015 11:17 AM
