Interior lighting at night!
Old Oct 25, 2014 | 09:49 PM
buzboy's Avatar
Can someone please post some pics of the interior lighting of the 3rd gen TL's please? I want to know what bulbs I have burned out in my 2004.
PLEEEEEEEEASE
Old Oct 25, 2014 | 10:34 PM
guitarplayer16's Avatar
Are you referring to dome lights or button backlight.
Dome lights don't go out much, but I just don't want to assume what you mean so let's clarify.
Old Oct 25, 2014 | 10:41 PM
buzboy's Avatar
Im referring to button back lighting
Old Oct 25, 2014 | 10:44 PM
paperboy42190's Avatar
the button backlight is more work to change
Old Oct 25, 2014 | 10:56 PM
buzboy's Avatar
Oh yes Im well aware. I changed the bulb in my hazard flasher tonight and low and behold, now my passenger side Auto climate button does not light up at the top. lol
Oh well what can one expect. It has over 170k miles on it and its an 04. 10 years old and counting!
Old Oct 26, 2014 | 01:21 AM
i recommend changing all of them at once, since this isnt a project you want to do multiple times
Old Oct 26, 2014 | 09:27 AM
joryramosn's Avatar
OP, If you are up for the task, I'd recommend replacing at least the climate control ones for Neo Wedge LED's. They are just plug and play. I'm happy with it. You can get a 10 pack on ebay for $12.
Here's the pic!
Old Oct 26, 2014 | 09:59 AM
Slpr04UA6's Avatar
-------Tim-------
^canadien TL? Your location is Houston?
I saw 25 on HVAC and thought "Damn, I never knew it went that Cool!". Lol!
Old Oct 26, 2014 | 10:32 AM
joryramosn's Avatar
Mexican market TL. I'm used to all in metric except the tire pressure. I have always used PSI so reading it as kPa now is a challenge :P
Old Oct 26, 2014 | 11:22 AM
Oh Sickest TL's Avatar
Jeff
101 kpa = 14.7 psi
Old Oct 26, 2014 | 11:29 AM
The ONLY reason that's stopping me from doing the T3 Neo wedge LEDs is the fact that not all buttons are T3, some are soldered. The ones that are soldered are the one in the overhead console, the radio, the lighting on the dor panel (window switch, memory, etc). I don't have the skills or patience to solder them, so that's why I never bothered.
Old Oct 26, 2014 | 01:44 PM
McDonaldSutherland's Avatar
6th Gear
My fan control light has died, as well as memory position 1 light...strange. Must be a Honda thing as my Dad's 2005 Pilots fan control lights burnt out too
Old Oct 26, 2014 | 01:49 PM
buzboy's Avatar
Thanks for that pic Joryramosn! Yours must be an 07? I dont know if I have that airbag light next to the flasher sign. I am definitely getting those LED wedges. I bought a new old stock center display off ebay for $135. Dealer wants new over $1000 AND without the side buttons. Also, my old display does not light up the amber dot when the defrost is pushed. That's one of those bastard soldered in lights. So after I get the new one, I will try to fix my old one and keep it for a spare
Old Oct 30, 2014 | 09:56 PM
6spdtl04am's Avatar
I've tried a few of these led's. The only thing is that at night it gets a little too bright and you really cant dim them. I only changed out the trunk release, dimmer switch, select reset, seat heater, hazard switch, and vsa switch.
Old Oct 30, 2014 | 11:06 PM
vietxquangstah's Avatar
Do they dim at all?
Feb 25, 2020 09:57 AM
handsom-hustla
Nov 13, 2015 05:04 PM
redsox68
Sep 16, 2015 06:18 PM
PortlandRL
Sep 14, 2015 12:01 PM
oyayjoe
Sep 12, 2015 04:40 PM
