Impact wrench recommendations?
Old Jun 19, 2012 | 12:44 AM
tonester's Avatar
I'm planning to get either an electric or cordless impact wrench soon for my timing belt change on my TL (to remove the crank pulley). I was wondering if anyone here can recommend one to me. I like to stay under $300 if getting a cordless one.
thanks
Old Jun 19, 2012 | 06:30 AM
truonghthe's Avatar
Snap On is the sh*t.
Old Jun 19, 2012 | 06:46 AM
Turbonut's Avatar
Many posts on doing the job, but in my opinion an impact wrench with the torque needed to remove that bolt is quite expensive for one time uasage, so use the breaker bar method with an impact socket rather than the regular run of the mill chrome socket. If you still want to use an impact, battery, large capacity e.g. IR or if air you'll neeed a large tank and large ID air hose to produce the needed torque to remove the bolt.
Honda Service Bulletin
Remove Stubborn Crank Pulley Bolts
Although our crankshaft pulley bolts are high quality,
they may stick to the crankshaft threads when properly
torqued. In fact, a properly torqued pulley bolt may
require up to two or three times the installation torque to
remove! (Now there’s a job for the proverbial two men
and a boy!) Here’s how we remove these stubborn
pulley bolts:
1. Insert the appropriate crank pulley holder into the
pulley. (See S/B 92-040, “Crankshaft Pulley
Holder,” filed under Special Tools.)
2. Support the crank pulley holder handle with a jack
stand or transmission jack to get the weight of the
car working for you.
3. Use a high-strength, long-handled, breaker bar with
an impact socket to remove the bolt (which has
right-hand threads). Try a 36-inch breaker bar if you
have one (though there may be times when a bar 48
– 60 inches long would be nice).
When you reinstall the bolt, lubricate the threads and
flange with motor oil, but don’t lube the washer or
pulley. Retorque the bolt to the specs in the appropriate
S/M. The torque is critical; don’t skimp just because you
had a hard time removing the bolt.
Old Jun 19, 2012 | 07:07 AM
johnny3's Avatar
You cannot buy an impact wrench for $300 that will break that bolt loose.
Old Jun 19, 2012 | 07:59 AM
flyromeo3's Avatar
I have NEVER been able to get a crank bolt off with a cordless impact. It's damn hard even with air tools.
You'll need a torch ! These Honda/Acura crank pully bolts will put you to work.
Old Jun 19, 2012 | 09:12 AM
ez12a's Avatar
the overexplainer
I did the timing belt last weekend.
I agree purchasing a compressor/pneumatic impact or a cordless just for this job is a lot of money to spend.
A big 1/2 breaker bar didnt work even with a 6 ft long pipe. I just twisted the setup 90 degrees with no avail.
I used the starter trick on the CP. It was my last resort, but it worked, and honestly would've saved me half an hour. If you go this route, I would unplug the fuel pump fuse and unplug all the coil packs before trying to crank it.
Old Jun 19, 2012 | 11:09 AM
ZOMGVTEK's Avatar
I spent a VERY long time breaking tools trying to get the crank pulley bolt out on my Accord.
I finally resorted to the starter bump method, and it worked great the second time around. Super easy and fast, and you don't need the holder tool (that was useless on the aftermarket pulley anyways). It sure did shake the car a bit more than I anticipated.
Old Jun 19, 2012 | 11:33 AM
quanaman's Avatar
TL-S
I just got one from sears for 100$. It advertises 200 lbs of torque. Not sure if it will work for what you need it for but I got it basically just for swapping weeks. It's cordless with a battery.
Old Jun 19, 2012 | 11:58 AM
ez12a's Avatar
the overexplainer
^unfortunately most likely not in this case, since the CP bolt torque spec to tighten it is 181 lbs. It will most definitely take well over 200 to undo it unless it was previously undone.
Old Jun 19, 2012 | 12:46 PM
flyromeo3's Avatar
x2..thats what I did to remove my crankbolt from my accord.
Old Jun 19, 2012 | 07:54 PM
truonghthe's Avatar
I remembered the starter trick when I had my Legend lol.
Old Jun 19, 2012 | 09:42 PM
Bearcat94's Avatar
AZ Community Team
thanks
Cordless impact wrench and Crank Pulley.
Good luck with that.
Try this thread (Kennedy's post on Page 1) instead:
A-098: DIY: UR Crank Pulley info
https://acurazine.com/forums/showthread.php?t=153549
Old Jun 19, 2012 | 09:54 PM
Turbonut's Avatar
You can get a cordless impact IR (Ingersoll Rand) 780 ft lb reverse torque and 1000 ft lb nut busting torque.
Used the starter method many years ago on GM cars that needed the timing chain, cam gear, and/or camshafts replaced, never had a problem, but in retrospect would rather have used a tool to remove the nut but those cars had no tool to hold the crank from turning.
Old Jun 19, 2012 | 10:09 PM
rockstar143's Avatar
I just did the lightweight pulley on mine...
mechanic at work works on fleet vehicles...he hit my pulley bolt with his ingersoll rand 800 dollar gun with the proper sized air hose and it came right off...didn't even need to hold the pulley in place.
J. Good luck!
Old Jun 19, 2012 | 10:14 PM
Tehvine's Avatar
6spd FTW
My IR 650 air takes off the crank bolts no problem. I only use a little 25gal dewalt compressor, but big hoses and a decent gun.
Old Jun 19, 2012 | 10:29 PM
Yeah, that's what the guy at work told me, the bigger diameter hose is what makes the biggest difference.
Old Jun 19, 2012 | 11:30 PM
nfnsquared's Avatar
OP, rather than spend the money on an impact wrench (you'll need one with at least 400 ft-lbs of torque, but probably more like 600), just find a shop to pop the bolt for you, then retorque the bolt and drive home.
It will now come off easily... Shouldn't cost you more than $50, if that...
Old Jun 19, 2012 | 11:44 PM
Azndjay's Avatar
MV612
i use harborfreight impact gun for 100$ so far so good . takes out all the rusted bolts i throw at it..but you also have to match your compressor to match the avg output of the impact gun..rent a compressor n impact gun ...
Old Jun 20, 2012 | 11:47 PM
Tehvine's Avatar
6spd FTW
Speaking of harbor freight impacts... I've always wanted to buy this because it is completely ridiculous. http://www.harborfreight.com/1-profe...vil-68429.html
Old Jun 21, 2012 | 06:25 AM
truonghthe's Avatar
here is a video for you OP.
Old Jun 21, 2012 | 07:36 AM
What a badazz video.
Yeah, that 1" anvil hammer is awesome...I have their 650 ft/lb Earthquake one, but not sure it would have gotten the job done.
Old Jun 24, 2012 | 12:53 PM
sauceja's Avatar
Desert Life Sucks!!
My nitro cat pnuematic hasn't failed me yet. It is rated at I believe 1000 or 1100 ft/lb torque in reverse. I bought it for crank pulley and axle nuts specifically. I bought it while it was still under 250.00 now I think they are more. Snap-on is good also.
I have done several timing belt jobs in my garage and driveway.
I have not tried to remove the one on my TL yet though.
Old Jun 24, 2012 | 12:59 PM
truonghthe's Avatar
^^^at least not yet.
Old Jun 24, 2012 | 06:45 PM
paperboy42190's Avatar
Remember that a lot of impact wrenches rate their torque in inch-pounds which is deceiving.
Old Jun 24, 2012 | 07:45 PM
Turbonut's Avatar
Not when they are 1/2" and 3/4" drive. Mighty whimpy wrench if it's 840 in lbs, that's only 70 ft lbs.
Old Jun 24, 2012 | 08:19 PM
Azndjay's Avatar
MV612
where do you see that every where i look is rated at ft lbs...all impact guns are rated ft lbs. I like to see this info.
Old Jun 24, 2012 | 09:23 PM
mindanaomoro's Avatar
I have Milwaukee M18 cordless impact wrench, I've used it on my TL, pilot, & 3 accords V6 and older inline 4 engines with no issues taking out the cp bolts.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
San Yasin
Sep 29, 2015 10:52 AM
adreano17
Sep 29, 2015 08:48 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
