im tryin to change my crank in my j32 w the mdxs j37 anyone know anything about that
05 two tone tl
i am tryin to put a j37 crank in and im wondering if it will have the clearance in the block . i am getting aftermarket rods and pistons. does anyone know if this will work or should i just get the j37 block?also are there ant other problems i might run inyo w the j32 heads fitting on. the car is also supercharged if that helps. thanks to whom ever can help
i know the 3.5 pistons and crank fit....but then heavy modding on the computer n sensors has to be done....the 3.7 i really dont know becuase it does come off of the AWD drivetrain and may be longer or maybe shorter or shortened in height or even heightened....who knows. only way to tell is taking it all apart n playing around.....if u have the time n money do it..... otherwise dont try to reinvent the wheel.
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
C2CuSn07 TL
09-11-2015 06:54 PM
35, acura, block, computer, crank, crankchaft, crankshaft, heads, j32, j37, pipes, pistons, race, rods, supercharger
