I'm at a dead end. Need advice
I'm doing good with my car since I bought it last year. I don't have a garage but things still go well. Last month, my apartment decided to improve landscape so they start the auto-water system ( I don't know what does it call ). The parking lot is close to the grass (there is the other one, which is more empty but they close to the trees ). The first week they did that, I think there is no problem at all but after a few days I realized that the water is not regular tap water. So I decided to move my car to the other lot, which close to the trees, I think my car will be okay there. The nightmare comes. Everyday I see the bird craps on the car ( yes everyday ). Although the car is washed every weekend, the marks of the bird crap stay there ( thanks to Texas heat
). I can't think of any ideas to solve my problems anymore. The bird craps drive me crazy. I seek of ideas now guys.
that's all I do every day but you know the Texas heat. All of them combine together ruin my car paint.
Move your car back to the original spot & place a flat piece of wood (or similar) between your car and the sprinkler in question. Make sure this object is as close to the sprinkler as possible and high enough to block liquid gold from spraying on your car once the sprinkler extends. Use your artistic skills to make it blend with the landscape..
Disclaimer: Assuming this is not against your community's rules & regulations
OR
Talk to the Manager at the Apartment Complex have them install guards like this to block the water from going anywhere but the grass. It will help them save money on their water bill even tho they probably charge you guys for it anyways...
OR!!!(this is what i would do)
Order yourself this sprinkler Guard and put it near the spinkler head every night you park and take it with you when you leave. Just throw it in the trunk They are pretty cheap on amazon... Cost around 10.00 with shipping. heres the link http://www.amazon.com/dp/B000VJDXHC/...SIN=B000VJDXHC
Somehow I feel that too, because there is no or rarely have bird craps on the ground but all on my 2 cars
I try the other empty spots already but so far is no .
.I try the other empty spots already but so far is no .
Since often bird crap happens during the night, it's not reasonable to expect him to be out there cleaning it every time a bird shits on the car. The Texas heat is a legitimate issue. Maybe adjust your schedule so as to wake up earlier in the morning to try to wipe off the bird crap or the water spots before it gets really hot outside?
As far as the sprinkler heads go, you should be able to find them even when they're not watering. They generally lower themselves to about flush with ground level when they're not in use (this so that they don't get destroyed when the grass is mowed).
lighten up francis....
OP, check and see if there is a car wash in your area that has an "all you can wash" pass. I pay $30 a month and can have it washed whenever I want.... Or if that's too much, a bucket and some soap with a sponge is a cheaper solution.
They shouldn't be hard to spot and remember the locations, and it would be an easy fix then spending money on a car wash every day or every time you get Bird shit on ur car LMAO GL
Attack the root of the issue. It's really, really simple to adjust the sprinkler heads yourself if you want to take matters into your own hands. I have to park outside when I'm at my moms house and her sprinklers were drenching my car (with the gross water they pump out from the lake behind their house), so I figured out how to adjust where they spray. Go look at the brand of the heads...Toro, Rainbird, Hunter, etc and google "How to adjust _____ sprinkler heads". A slew of results will come up. Basically there's a screw on top that adjusts the flow and a screw that adjust the rotation. It'll take 5 minutes tops. Go out and do it while they're on.
If they see you, they can't possibly get pissed at you for correcting their problem. I doubt anyone will even notice that the sidewalk and parking lot aren't being watered anymore.
