If steering is off by a hair, could I just move it one spline over?
I've been to the dealership multiple times for an alignment, each time I brought it in they say it's in spec. Tires are fairly new and everything checks out. Now on the highways it's a hairline off to the right which is annoying, would it be possible to just take the steering wheel off and move it one spline over to the left? Trust me, I've tried to get this done the right way but "I'm in spec" thoughts?
Now if you're talking about a very slight pull to the right, that's a different story.
I brought it to the dealer twice, the thing is that this dealer is always busy making you wait for a long period of time. They said it was in spec and showed me the papers, I'm just pissed because I paid for this service and was given "warranty" obviously they are not doing anything about it making me having to resort to this, also I don't really want to spend more money on an alignment if tire wear is perfect, just that hair off on long drives can be annoying as your struggling to hold the steering wheel at a slight angle.
AZ Community Team
Received 7,770 Likes
Once again, as per usual, IHC is correct.
There is an Acura procedure to check and adjust the steering wheel straightness. It's exactly for cases like this - alignment numbers are good, but the steering wheel is off center.
This is getting scary as we agree once again, this time about the dealership being lazy.
Although it can be done on some cars, don't ever change the wheel position as it will take it out of the R&P center position, or steering gear center.
Just for your info, to adjust the wheel properly back to the 12 o'clock position, they need to put it on the alignment rack and straighten the wheel by adjusting the tie rod ends, one side in a specific number of turns and the opposite side out the exact same number of turns. This can also be done without an alignment rack, but common sense would dictate the final setting be checked to ensure the toe is within the factory values.
You've paid for an alignment twice, and with no adjustments needed everybody came away happy, except for you. As it was a quick money maker for the dealership and Tech, it is now time for them to correct the situation, so go back and tell them you want the wheel straight. If it's been a while, they probably won't do it free gratis, but I would certainly push for consideration in the matter as you have receipts that it's been done twice before and neither time correctly.
MMkay.
agreed; if the alignment if the wheel is straight (where you would like it to be) and it's pulling to a side. Something's off..I actually work at an Acura Dealership and they have a bar that holds the steering wheel in place while it pushes against the seat so it won't budge during adjustment.ask to speak to service manager;and if they also give you the run around say very politely "who's your general manager here?". I can almost assure you you'll leave with a straight steering wheel and a car wash.
The thing is that the person who is pushing me around is the service manager! Anywho I just don't have the time to drop it off and wait, they made me wait an hour and a half last time just to tell me their in spec. I was hoping to fix this myself on my free time if I could.
Desert Life Sucks!!
You have been dealing with the SERVICE Manager. You need to contact the General Manager.
Call corporate. They love getting involved when customers are displeased. Honda/Acura really sticks to the done right the first time approach. And the district goes by how many cases were not done so which lowers their rating.
Call corporate.
Call corporate.
iWhine S/C 6MT TL
Ive done alignments and even with the steering wheel holder the alignment was off, that was mainly the alignment heads going out of wack. There's been many times where after a road test I would say "Shit the wheel is off center" by very little but it's not acceptable in my book so I do another alignment which the 2nd time fixes it. It's better to lose time on a job then to deal with an unhappy customer and a pissed off boss.. Take it back and let them know the wheel is off center and would like the alignment to be checked again.
rhafikjaan (09-09-2011)
I would love to take it back but I don't really have the time and it's my only transportation besides my bike since it's raining I can't take that. I might call corporate, the thing is that I haven't been back to them since I noticed it in like 2 months so I don't know if coporate will care because of that. I'm afraid to take it back just incase they dog the car or not torque the lug nuts like they did last time or just not giving a damn about my vehicle.
Kinda worried about doing this lol
This is the problem, you'll be taking time to adjust the wheel, just unlock the steering wheel with the ignition switch, loosen the tie-rod lock nut, put a caulk mark on the threads for reference, turn the nut on the rack a few turns to shorten the right side and elongate the left side, but if not done correctly you'll be in for another alignment. You'll have spent time trying to adjust the wheel, and then you'll also be spending time and money for another alignment. Call the dealership and explain your situation that you can't live with the wheel off-center anymore, see what they can do for you and set up an appt. rather than taking it in and wasting time negotiating. If they won't do anything, take time out and go elsewhere. Just don't leave if it's not to your liking.
I still think he needs to demand they do it right and/or move higher up on the dealer food chain with his problem. Maybe he can bring in a copy of the manual with the part about centering the wheel highlighted. It's sad but maybe it's necessary.
Ok I finally brought it and dropped it off at the dealership at 9am and they had it for 4 hours. I haven't had a chance to drive it at highway speeds yet but I went for a ride with the tech and he said everything checks out and in spec on the alignment rack. Then he said he adjusted the tie rods a little bit just so I wouldn't have an issue. He even braked hard a few times to show that the car is not drifting away. I told him I'll drop him off and bring it back if it keeps doing it when I test drive later.
Wow, i'm experiencing the same problem. I took it to the dealer already and they too have said the alignment was "in spec". Obviously they havent driven my car around town. It steers slightly to the right on center. It was such a pain to make the appointment to get it serviced too.. ugh
I'm always sort of scared to have my car aligned because of stuff like this. Way too many times I take it in with the wheel nice and straight and get it back all jacked up, but "in spec" Trouble is most techs don't give a shit. If you know people who autocross, find out where they get alignments done. Typically they're used to doing non-stock specs *and* having picky customers that want the alignment perfect, not 'close enough'
Desert Life Sucks!!
mine is off a little also has been since I bought it. I was gonna fix problem after new rims/tires but have time off for 2 weeks so gonna fix it.
I know a guy locally that is soo busy he lets me pull on alignment rack and sets out the tools for me to do it.
I used to reset and check alignment on my hatch every time I took it to the track to make sure I wasn't off.
It seems intimidating but really isn't that scary. But I am a firm believer if you are not confident in doing it then DON'T. Let someone that is and/or has the correct machinery to do the job correctly.
I don't mean to jack the thread, but I have the same issue.
but when i'm in the first lane (banked toward left) I have to steer right by a hair.
then when I'm in right lane or anywhere banked toward right, I have to steer little to the left to make the car go straight..
Try in different lanes,, i guess.
acuratl26
04-23-2020 07:30 PM
ITSJESTER
17
12-06-2018 02:29 AM
