I Wish
Bello
I Wish
I wish That all of these thing could be bought!
The Acura TL Thunder hill edition Hood.
A supercharger for the TL-S or even a Turbo charger i really don't care.
An Air intake that doesn't require you to take off the front bumper.
A sway Bar.
A factory Ipod Connector to the Navi.
If any of this objects are for sale, which i don't think they do plz let me know i will purchase and put it on in 2 weeks tops.
this is just my wish list.
thanks for reading.
A sway Bar.
thanks for reading.
Turd Polisher
Even if it was for sale, how would you be able to afford all of that? lol.
A sway bar is available for purchase and it is not necessary to take off the front bumper to install an intake; you can take the wheel off and go through the wheel well.
What is the Thunder Hill Hood?
Turd Polisher
Also, what's so hard about taking off the front bumper?
I did the intake install with NO PRIOR experience in less than an hour and 30 minutes.
I say go for it
I say go for it
Bello
http://img.infocoches.com/img/acura/...hill-016_0.jpg
Look close its really cool.
http://araba.resimleri.tv/albums/use...llpaper_01.jpg
Originally Posted by speedy1991mia
O its cause A-c-u-r-a-w-o-r-l-d-.-c-o-m comes befor/forums/f72/acura-tl-makes-impressive-splash-25-hours-thunderhill-52092/
Your TL-S should have a factory Ipod connector input. It's in the compartment under the armrest. Or are you talking about being able to control the Ipod through your Navi? Like being able to switch tracks?
My only gripe about the location of the Ipod input is that on the 07 there's no hole for the input cord to come out of the compartment. If you close the armrest box it pinches the cord and it's ripped away some of the insulation on it. I may take a dremel and cut a piece of the plastic out of the armrest underneath to allow the cord to come out... at some point.
Bello
No Need
I used to have the same problem but if you open the top part to the compartment on the left hand side there is a slight. I put the AUX and my ipod charger through there. And yes I'm referring to Navi access.
Hah man I'm a retard, just looked again over lunch and found the hole that comes from the lowest compartment and the groove that lets you bring the Ipod out of the center console :smack:
94 DC4 RS LSV/Turbo
answering your wishlist....
Thunderhill Hood... pop your hood, you will see a fabric like material... it has 6 to 8 circular clips that hold it on to the hood... remove the entire portion, now you have access to the support designs on the tl... you will see there are 4 triangles dead center... this is where the thunderhill tl team cut and folded down, then added a trim....
s/c... the comptech supercharger will bolt up no problem, you will just have to get a tune..
intake that doesn't require bumper removal... 2 choices... get a short ram... or remove the battery and driver tire, then rip out all the plastic lol
Ipod connector is available at the dealer... it is an accessory i believe it is like 200 or so
steeez
check this hood
https://acurazine.com/forums/showthread.php?t=166908
i dont like either, but theres another option for you
