I need help! NOW!!!
Old Mar 25, 2006 | 04:54 PM
TL CHROMETIDE's Avatar
To punish and enslave
I need help! NOW!!!
I was going under the hood of the TL, checking a few things. I unscrewed the engine oil fill cap and I dropped it! It fell somewhere under the hood but I can't find. Is it okay to drive without the engine oil fill cap on. I can't find it and my parents are going to kill me. I'll have to buy a replacement if I can't find but is it okay to drive the car without an engine oil fill cap?
Thanks!
Old Mar 25, 2006 | 04:57 PM
EternaLlx's Avatar
6speed NBP
find something to cover that thing rite now! plastic over and rubberband(dont drop those into the engine tho..... or ur screwed) dont drive with out the cap dirt and stuff will enter your engine and can scratch up the cylinders!
Old Mar 25, 2006 | 05:34 PM
levon1830's Avatar
You can't drive the car with EternaLlx's temporary cover, which is a good idea. You're gonna have to catch a ride with someone to your local auto parts store and get a replacement cap.
EDIT: Actually, I don't think you'll be able to rubber band it... there isn't a lip to attach the rubber band to. You need to sit something on top of it.
Old Mar 25, 2006 | 05:42 PM
EternaLlx's Avatar
6speed NBP
plastic cover and tape it around the engine top cover? hahhaha yeah dont drive till you get a cap for it
Old Mar 25, 2006 | 05:46 PM
proxus's Avatar
i bet its stuck on the subframe.. go under the car and look for wide steel bars under the motor. Feel around on top of the frame and see if u can find it.
Old Mar 25, 2006 | 06:17 PM
Brettg's Avatar
it will look like a big vacuum leak and set a cel most likely, and/or make an oil mess under the hood.
Its likely stuck on something under the engine.
Brett
Old Mar 25, 2006 | 06:56 PM
Problem solved! I finally found the cap on top some plastic thing at the bottom near the sub-frame. It was a hard reach because I had to manuver my huge hand and arm around hose and wires but I finally got it. Thanks very much to those who replied. God answered my prayers
Old Mar 25, 2006 | 08:27 PM
zootjeff's Avatar
Just turn the car upside down and shake it.
Any ammount of flashlights going to help you?
Old Mar 25, 2006 | 08:36 PM
MichaelBenz's Avatar
CTS-V Import Slayer
Good deal...I was gonna say...dont drive it....gonna make a HUGE mess as it most likely spits out little spatters of oil. Not to mention comtaminants. NEVER good to drive without oil cap! You could get away with it for a short while on very OLD oldsmobile engines as they had a filler neck at the front of the engine and it wouldnt "spit" oil....but these days....NO GO on just about every motor! Isnt like the old days where a rag would work!
Old Mar 26, 2006 | 08:55 AM
JohnDoe2's Avatar
Thanks!
You just had to futz with it, didn't ya.
Old Mar 26, 2006 | 03:14 PM
Yeah, I was just a curious.
