How would I go about adding a button to the Dash?
2004 TL
There is that extra button slot next to the side mirror and traction control buttons. How can i open that slot up and put something in it so it looks good and stays in place? I looked through the garage and did not find anything to help me.. Thanks!!!!!!!
EDIT: I want to add something like this... http://www.radioshack.com/product/in...ductId=3097457 To power a few things all at once.
7th Gear
I've often thought that something belonged in that very same space.
I imagine that if you have (or get access to) the service manual, you can get the disassembly instructions to properly access that portion of the dash.
At that point, it's up to you and your good taste to select the proper looking switch (and one that will handle the power requirements of the item(s) you wish to control with it). Be careful powering multiple items, as a switch that gets too hot (overloaded) can deform or melt the plastic it will be mounted in.
if you look at the switch that you linked to, it looks like the mounting mechanism is simply a threaded collar that locks the switch in place from behind. From what I can tell, the switch you linked to would have that entire rectangular plastic switch housing above the point where you mount it.
If you have doubts about how well the switch will match with the interior, you can find thousands of different switch types at different online dealers. Someone here can likely receommend a reputable one.
::lc::
::lc::
2004 TL
Yeah, I would not put it in there if it was serious work to get the wiring behind there. I would just put it somewhere convenient for me that takes a lot less work. Just curious how I would go about doing it.
Mistuh DRiiVA
Its not really that hard to get to that slot and there is ample space behing there to run wiring for your devices. I have a 2005 TL with the accord fog mod and also have independant stock fogs so i have two switches in that slot turned horizontally instead of placed vertically. I have enough wiring running back there and there is ample space back there for them to rest. TO remove the dash is very easy, all you have to do is remove the plate under the dash then pull on the dash easily where the tabs are located and the bottom panel where the switch is will fall out then its easy to pop out the switch cap and modifiy for your switch.
2004 TL
https://www.heeltoeauto.com/Honda-Ac...X-pr-4602.html
anyone know where i could get one cheaper? or one that fits in perfectly but not an oem part?
Received 6,470 Likes
Powerflow is definitely showing you the proper place to put the switch. But the one you found on Heel/Toe looks more OEM. But Powerflow's is a lot cheaper, obviously. I don't know what Triod's suggestion costs, but it's possibly your best bet! Your choice.....
2004 TL
what did u search for on this site to find that? And how many things do u have hooked up to it. Will it be able to handle 3 different things hooked up to that one switch. ty
it's me, Alan Rickman.
2004 TL
Yeah, I would be hooking up multiple things to one switch.... so I cant use the one that fits, I am going to have to go to radio shack and get a multi purpose one and find a place to put it lol. Any multi work? or do i have to buy one that has a set amount for the amount of things I want to use?
2004 TL
ok so hook up multiple things to one switch I will need a relay. Anyone have a link to where I can buy one of these for a low price. I dont even know what to look up to find these. i am going to look now but if anyone knows of a good one link me to it. Thanks.
2004 TL
http://www.wiringproducts.com/contents/en-us/p564.html
Would this work? Want to be sure the one i get will be able to handle multiple things at once.
soupi
14
11-15-2015 11:15 AM
spoiler900
10-10-2015 06:48 PM
