How to remove the rear "A" emblem?
Old Jun 1, 2011 | 09:39 PM
donaldso718's Avatar
I couldn't find an exact DIY or any details on how to remove the rear "A" emblem? I need to remove it to paint, can someone explain or show me how? Thanks.
Old Jun 1, 2011 | 10:03 PM
AcRightLINY's Avatar
baller on a budget, b!tch
You can remove it simply by using the same technique as you did taking the other badges off.
Problem is you'll have 2 holes left on the trunk. I think that'd be something you'd bring to a shop to have bondo'd/painted. Kind of alot of work for a minor detail IMO.
EDIT: Err. I misread your post. Using a heat gun and either floss, or fishing line, apply a little heat around the emblem, and get behind it using the floss/fishing line. Use a sawing motion to cut through the adhesive and it will pop right off.
Old Jun 1, 2011 | 10:13 PM
But aren't there some screws in the back of the emblem? Ive taken off the other emblems using the same method, but those did not have any holes. I was just assuming this would be a bit different since there were holes. So I should just use heat and floss also? Thanks!
Old Jun 1, 2011 | 10:19 PM
Bearcat94's Avatar
AZ Community Team
Not screws. Pins. They just pry/wiggle them out.
Then when you put it back on, painted, put some 2-sided tape and align the pins with the holes in the deck lid.
Old Jun 1, 2011 | 10:36 PM
Sickboy722's Avatar
2006 Acura TL
No there is no screws in the back they simply just pop off, I used a flat head screw driver with a towel at the end so I wouldn't scratch the paint
Old Jun 1, 2011 | 10:43 PM
CLtotheTL32's Avatar
^The problem with doing that is the emblem may crack since it's rather thin and hollow.
OP I loosened around my emblem with floss and such and then took off the trunk lining and pushed the emblem out that way.
Old Jun 13, 2011 | 04:52 PM
Sickboy722's Avatar
2006 Acura TL
^yeah thats true, i got lucky mine didn't crack
Feb 25, 2020 09:57 AM
HOWELLiNC
3G TL Photograph Gallery
24
Oct 8, 2015 03:15 PM
Dunnik
Sep 15, 2015 11:52 PM
