How to Remove the panels on the bottom of the door, center pillars, and rubber seal..
Does anyone have a link to or have scanned in the instructions for removing the door sills, the center pillars, the door seal etc.... so that I can run some RCA cables.
That should do it....it seems that I have to remove the rubber seals.....they call them 'trim's
I was not sure, so I wanted to check before I did that.
You have anything for getting to the stock amplifier and removing it with wiring diagrams for it also?
Thanks ALOT!
Thanks ALOT!
The stock amplifier is behind the right hand kick panel. The instructions for removing the kick panel are on page 20-62, which is in the thread link I gave you.
The wiring diagrams are in the electrical manual, which I don't have.
Oakes
Wash & Wax
10-12-2015 11:17 AM
