How often MID requires ATF change after 1st one (60K miles)
Anyone knows how often the MID states a Automatic Transmission Fluid is required after the first change at around 60K miles?
yeah every 30K unless you live in rush hour traffic, then I would do it once a year.
read the gen2 horror stories and you will want to change it once a year-
do at least the minimal 3 qt drain and replace.
Some do a full changeout with 9 or 12 qts..about 100 bucks worth of fluid total but good insurance on the trans,,plus if ever a problem acura is more willing to help cars with documented trans care
The failures were attributed to certain driving conditions that could overheat second gear and create a transmission problem. Changing of the ATF would not have eliminated this problem, as only the revision to the cooler line that increased the flow of lubricant would correct this condition. When the cars were brand new people experienced this transmission problem.
Actually the ATF fluid is 100,000 mile fluid and to be changed at this interval unless under severe conditions than 60,000 miles. Certainly changing sooner isn’t going to hurt anything other than your pocket.
I fixed the glitch
I changed mine out this weekend at 59K. It looked ok but I drive mainly highway. Mobil 1 ATF seems to be working well. I think I'll end up draining 3 and refilling 3 every 10K, just for cheap insurance.
if you want to know for certain- take a 4 ounce sample and send to oil lab like www.blackstone-labs.com for about 30-40 dollars
they run it thru a mass spectrometer and give printout of all metals and materials in the fluid, the average of all cars tested and the average of your type car
Make suggestion of replace fluid or how much longer you can run it for based on current condition
Im gen2 with trans probs--so I am biased,,fluid at 20k on warranty #1 smells burnt
so its into the dealer--again
AND turbo is correct, it wont cure the general prob of not enough oil going to 2nd- 3rd gear clutches,, AND it cant hurt to keep up on it well before 100 if you drive on Earth
Info: The auto trans clutches are similar to motorcyle `wet clutches`- with several thin plates of friction material stacked on top of each other that keep the trans engaged in gear
When that material gets worn from use, the trans starts to slip and doesnt like to hook up / get friction in the next gear
The prob with waiting to change is the new fluid contains a lot of cleaners which may wash away the crud that was holding the remaining friction material still in place!
At that point the trans already had a problem but now its an immediate problem
best way to avoid prob- watch the use of SS and MAX rpm downshifts into 2nd-3rd
in everyday driving
A track day or several wont hurt it like bad street use will
your everyday freeway use to slow the car is really bad for it and in town- heat in the trans rises
Use the Brakes to slow the car, and the trans to make it go faster
use SS to be in the right rpm-torque/ gear to accellerate off the corner,,
not to use it as brake coming off freeway normally (exceptions apply-these are general)
in everyday driving
I was in the dealership today for oil, trans, and differ. oil change and my service rep. informed me that changing the transmission fluid too many times isnt very good for my car! Has anyone had precious problems with the RL 05 transmission?
I dont think changing it repeatedly is bad depending on the intervals you use. If you change it every month thats just overkill and waste of money. I do my moms at 15k on her odyssey just to be safe just a simple drain and refill. But if you flush (using additives like the trans flush crap at autozone etc...) the trans often which I never recommend you can wear out components in the trans.
service writers are not techs!!!!!!-
only know how to write down complaint,, look up repair times/cost in the computer and SELL to you
I would ask them in front of the service manager~
I fixed the glitch
Exactly.
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
Why do u have to change the ATF every 30K since it states in the Owners Manual (pg. 213) that you should change your ATF every 30K miles if you drive in "mountainous areas with very low vehicle speed"
Same with the Timing Belt. Owners manual (same page) says change every 60K miles
Am I reading this wrong, or have i just misinterpreted everything?
(no threadjack)
(no threadjack)
Changing the fluid to many times can harm the transmissions, having an inexpereinced tech do the work can end in disaster. They could strip the bolt/plug for the trans fluid, forget to put in the new fluid, etc. The more you mess with it, the more problems can arise. As well if you are "flushing" using chemicals, you can damage the components in the trans. Use ONLY fluid and no detergents. 3 x 3 fluid exchange is the only way to do it right.
So would it be better to just leave it alone?
So would it be better to just leave it alone?![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
![what](https://acurazine.com/forums/images/smilies/what.gif)
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
Skirmich
09-15-2015 06:41 PM
