how do you increase the car remote range?
Old Apr 29, 2010 | 03:03 PM
winkyyy's Avatar
the range of my remote on my 08 tl-s isnt that great. is there a way to increase the range? i dont want to upgrade to an aftermarket alarm or anything. and my battery has recently been changed.
Old Apr 29, 2010 | 03:09 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Change the battery in the remote.
Old Apr 29, 2010 | 03:12 PM
crazyasiantl's Avatar
+1 on the battery
or you can just hold it up to your chin and see if that works
jk
there could be the possibilty of interference somewhere nearby
Old Apr 29, 2010 | 03:35 PM
dadon's Avatar
get rid of it and install a viper 5601/5701 and if you are balling 5901
Old Apr 29, 2010 | 03:49 PM
imj0257's Avatar
Q('.')=O
Hold it next to your head... gets like 20+ ft more distance.
Old Apr 29, 2010 | 05:25 PM
SouthernBoy's Avatar
Registered Member
This is true. Hold it up next to your jaw, pointed at your car and you will pick up quite a bit of extra distance with it. I measured mine to go close to 200' doing this.
Old Apr 29, 2010 | 05:31 PM
Hapa DC5's Avatar
אני עומד עם ישראל
wow 200? This trick has always came in handy I didn't know it helped that much.
Old Apr 29, 2010 | 05:55 PM
Riga89's Avatar
B A N N E D
Change the battery and hold it next to your chin when you press the button. This definitely works.
Old Apr 29, 2010 | 08:36 PM
flyromeo3's Avatar
not sure if this would help but, there's a method i've done with my s4 where I pulled the "antenna" from the rear quarter panel and ran it towards my c pillar and tucked it in that gap between the rear window. It does give me a bit of more range.
if acura has the same "antenna" for their remotes than you can probably give that a try.
Old Apr 29, 2010 | 08:39 PM
08A-SPEC's Avatar
I have a Viper 5901 in mine. I love to have the ablity to know if my car is being tampered with/bumped/etc... up to a mile away while my car is parked at work.
Old Apr 29, 2010 | 09:02 PM
maknwar's Avatar
DO you have a switch blade key? If so, how does that work?
Old Apr 29, 2010 | 09:12 PM
TeknoKing's Avatar
There is a battery that you can replace, size 1616.
Old Apr 29, 2010 | 09:13 PM
08A-SPEC's Avatar
Its a seperate remote and I just have my valet key.
The 5901 with the expresskit add on module interfaces with the OEM security system.
Old Apr 29, 2010 | 10:04 PM
DuoDSG's Avatar
Make it so
'Tis true. Your bone acts like a conductor for the signal, thereby increasing range.
It's the same principle at work as for phones for the deaf and hearing impaired, where they have no speaker and instead transmit sound through the bone.
It's one of those neat tricks that everyone always hears about, except this one actually works.
Old Apr 29, 2010 | 10:37 PM
cjTL's Avatar
I'm Craig
Wtf. Are the comments about holding it up to your jaw serious? I don't have signal problems, but I certainly don't want to look like a tard trying this if it doesn't actually help.
Old Apr 30, 2010 | 01:33 AM
crazy haitian's Avatar
WTF..tell me why the chin thing work
Old Apr 30, 2010 | 01:49 AM
CdTriX's Avatar
you think you have range problems? i have issues as soon as i get out of the car, i end up having to point the remote at the driver side dash on the outside for it to work.
freaking intermittent as hell. i have 2 fobs and 1 switchblade and they all do the same thing. if i unlock the door, i can't open the trunk for 10 seconds or vice versa.
the chin thing works most of the time imho.
Old Apr 30, 2010 | 02:07 AM
SpiderX1016's Avatar
It does work.
Old Apr 30, 2010 | 02:28 AM
Conan O'Brien's Avatar
just push the remote when you are closer to the car. works every time.
Old Apr 30, 2010 | 06:34 AM
LoveMyTL-S's Avatar
You think the range on the TL-S is bad, you should try a TSX, they are worse. The hold the FOB to the head thing really works, I've done this many times. And you don't look like a tard, no one notices. You only hold it up there for a second.
Old Apr 30, 2010 | 08:06 AM
Morrissey25's Avatar
contemplating future mods
Not gonna lie... I can't wait to try this out
Old Apr 30, 2010 | 08:08 AM
dadon's Avatar
yes siiir
and its only $325 on ebay, and easy to install if you know a little bit about
oh and the 5601 is $165 and its just as good but no two way remote
if you rather do the whole jaw thing ok..lmao
just get an alarm you will not regret it
im waiting on mine to arrive since i just got the car
Old Apr 30, 2010 | 10:35 AM
DuoDSG's Avatar
Make it so
Thumbs up
Your cranial cavity, when you point the remote up into it, acts like a natural amplifier for the signal, which can boost it by about a third.
Here's an article that explains it in a bit more depth:
http://www.unplggd.com/unplggd/look/...s-range-083663
Behold:
No, we are not pulling your leg on this one. This is real, it's pretty well-known and used (even if the science behind it isn't).
Old Apr 30, 2010 | 11:40 AM
LoveMyTL-S's Avatar
Perhaps the skull acts like and extended antenna??
Old Apr 30, 2010 | 11:43 AM
Cooper19's Avatar
Originally Posted by dadon
yes siiir
I have never used this online dealer, but ...
Viper 5901 - 2010 BLOWOUT SALE
LC3 SST LCD 2 Way Car Alarm With Remote Start System
Sale Price: $219.00
http://www.dealercostcaraudio.com/viper5901.aspx
Feb 25, 2020 09:57 AM
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
Mr.Tea
1/2G MDX (2001-2013)
26
Oct 9, 2015 04:27 PM
jordanboi
Sep 5, 2015 01:33 AM
Aug 30, 2015 02:39 PM
