How do you change the front signal bulbs???
Team SSM
Hey guys, I was wondering if anybody knew how to change the front two signal bulbs??? I tried looking in the 3G garage section, but nothing was listed for front signal bulbs. I was just curious.....just in case if i had to replace it in the future. Thanks.
Edit: need4speedposted later on that it is in the owner's manual, which I completely forgot. See page 213 for instructions, which give you a shortcut and are more complete and easier to understand.
First, you have to remove the inner fender. See scan below.
For the turn signal: disconnect the connector, turn the bulb socket 45 degrees counterclockwise, and remove it.
For the side marker light: Carefully push out the light from behind the fender. This is an led light, so there is no bulb to replace.
![](http://img.photobucket.com/albums/v204/myronaa/service%20manual%20scans/innerfenderreplacementpage20-142.jpg)
an Acura has-been
Look in the owners manual, you do not have to remove the whole liner, they designed a section to be able to pull away from the fender and reach in to get to the bulbs (you have to turn the wheel a certian way too, but much better than removing the whole liner
I edited my post above to include the owner's manual information.
Team SSM
Originally Posted by AcuraTL2k4
Are your headlights cleared? If they aren't its a waste of money to change the bulbs. You wont notices a difference in color.
an Acura has-been
Originally Posted by Ron A
Good catch. I completely forgot the instructions are in the owner's manual. Guess I'm so used to looking in the service manual for this kind of stuff.
