How do you change the fog light bulbs??
Hey everyone, I'm thinking about changing the nasty factory fog light bulbs on my 2005 TL but wanted to know if anyone has instructions (with pics) how do this this.
Also, would i be able to put HID's in the fog lights or not?
Found this thread in the 3G TL garage:
https://acurazine.com/forums/showpos...3&postcount=46
searching is you friend.
Registered Member
No, you cannot replace your fog lamps (which are 9006) with HID lamps. HID lamps require ballasts and different sockets. There are kits available, but give this some consideration first before buying a kit.
Team SSM
^ i agree. I just replaced my fogs with some Hoen Endurance bulbs. Driver side was easy. Passenger side took a while....its def harder because there are metal edges around the area of the bulb socket. I couldn't twist it hard enough to get it loose, so I ended up using some pilers and worked perfectly. Just gripped it and turned gently.
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
