How do I remove trunk lining?
FizzyStatus!
Hmmm ok so theres 11 pins..make sure you take all of em out. Don't quote me on that but when I did it thats how much I remember there were. ummm there a screw in the handle onthe inside of the trunk, Just look all around it and see what you're pulling on Let me know if yu need more help
where it wraps around the trunk hinge it is cut so you can pop it off the hinge itself. If you removed all the cargo net holders, you should be able to pull the liner away from the side enough to get to the sidemarkers and pop them out. Just pull out enough to get 1 arm in there and push the tab holding them in.
I still have not be able to remove the trunk lining, it seems it is stuck I do not want to pull to hard which might cause damage to the lining, any added advice on how to remove? Some one who has installed TLS side markers and rear lights?
BoricuaTL
04-08-2016 01:08 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
oyayjoe
09-12-2015 04:40 PM
