How to bleed clutch fluid
Looking for suggestions on a one-man way to bleed clutch fluid... I've gotten kind of frustrated with the v.
I'd prefer but I don't think there are any that fit our clutch reservoirs. Pls make some suggestions.
thanks.
thanks.
Just use the classic vacuum tube to a Mason jar two person process.
- but first make sure your bleed port is clear to pass fluid when bleed screw is opened.
- went through an 05 after purchase and there was so much hardened crud, had to remove and disassemble slave cylinder to clean out.
The DVD-A Script Guy
Also had bad luck with vacuum type bleeder. You might be able to fabricate a cap for a positive pressure method as it really doesn't need to seal for very high pressure. In the end I just went back to the two person process as racerock suggests.
You may want to limit the slave movement as described in this scan from the SM
dstah
05-13-2012 07:56 AM
