Higher Mileage Crew, let's talk BUSHINGS!
Old 04-28-2014, 10:14 PM
Fearless DIY Guy
DeathMetal's Avatar
So, she's getting up there for sure, and there's no doubt the compliance bushings are once again gone. While I will be replacing them in short order, aside from the compliance bushings, are there any others you'd recommend replacing?
Old 04-28-2014, 10:15 PM
Fearless DIY Guy
DeathMetal's Avatar
Also, while we're at it, has anyone made one better?
Old 04-28-2014, 11:32 PM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
I'm in the exact same boat, man.
I'm planning to order all 3 bushings (#9, #10, #11) as I'll be taking out the lower control arm myself and getting a shop to press the bushings out for me.
Heeltoe has aftermarket bushings, but they're really expensive.
http://www.heeltoeauto.com/fastline-...x-tl-tl-s.html
Old 04-28-2014, 11:40 PM
robocam's Avatar
Just out of curiosity, what mileage are you at? What signs and symptoms tell you that they're "gone?"
Originally Posted by DeathMetal
So, she's getting up there for sure, and there's no doubt the compliance bushings are once again gone...
Old 04-28-2014, 11:41 PM
https://acurazine.com/forums/3g-tl-problems-fixes-114/04-08-front-lower-control-arm-bushing-failure-please-read-look-707888/
Old 04-29-2014, 12:10 AM
Being an Acha Bacha in
Elegant TYPE S's Avatar
I always wondered if this is what leads to the deterioration in overall comfort and ride quality and characteristics of older cars. When new the car was nice and sturdy feeling and tight. Over the years even with proper routine maintainance of suspension components it's not like new.
Maybe someone can chime in.
I'm not only talking about the compliance bushings. I've replaced those under warranty several times and it didn't make much of difference for me atleast.
Old 04-29-2014, 01:43 AM
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
There's a lot of bushings in the rear. There's a lot more arms, but I haven't seen those go out yet, they seem to be a lot more durable or they undergo less stress.
For the front, besides the lower control arm there aren't many other bushings. There's the front sway bar bushing but no one wants to change that one at home lol
There are other rubber pieces like motor mounts that wear out, and couple ball joints
The following 2 users liked this post by paperboy42190:
cokorote (04-29-2014), JuicyLarry (07-01-2014)
Old 04-29-2014, 02:06 AM
robocam's Avatar
Mine look like that, but an independent shop checked them out when they worked on my transmission at 122k miles, and they told me they're fine. I don't think the tears affect their performance.
Originally Posted by paperboy42190
...There's the front sway bar bushing but no one wants to change that one at home lol
Haha, I had my sway bar bushings changed out when the transmission was being worked on (nothing wrong with them though). They only charged me for the parts ($6 each I think). The engine mount was also bad and was replaced. I was at 122k miles.
Old 04-29-2014, 08:33 AM
98vtec's Avatar
you cant expect one set of bushings to fix a "poor" ride quality on a high mileage vehicle. take my 92 Civic for example. 221k miles on it and the bushings were worn slap out. i replaced every single suspension bushing on it and it made all the difference. HardRace made the kit for the civic along with other companies like Skunk2 were i got front upper and rear lower control arms.
it doesnt matter if the bushings aren't torn or damaged, per sae. They all wear out and allow the pin to sag allowing more movement/travel.
I dont believe i could bare to have a full metal spherical bushings. But i wouldnt mind hearing more reviews than what is on their page.
Old 04-29-2014, 09:43 AM
This is a great thread. I would like to know all the bushings in the car that could be changed and could restore like new ride quality and feel.
For example in colder climates I feel the car is tighter and stiffer and nice compared to when weather is warmer outside. Then I feel the ride is more floaty and loose. I am going to go out on a limb and say this is due to compliance of the rubber bushings due to temperature change which makes
logical sense.
I really think its the subframe bushings that need to be changed to restore the ride I'm talking about it.
Old 04-29-2014, 11:02 AM
Moved to the LOU
twigglius's Avatar
I ordered and have received the three front bushings as well as rear bushings. I'm also replacing my rear trailing and control arms with ingalls. My car feels sloppy even with new coilovers... Its got to bebtje bushings. I hope. Car has 125k on it.
Old 04-29-2014, 11:12 AM
Moved to the LOU
twigglius's Avatar
I'll put up a parts list later. I also ordered all new nuts bolts and washers since those were not that expensive.
Old 04-29-2014, 11:34 AM
CL9 Jon's Avatar
Just buy complete replacement front LCA's... they're $60-70/shipped ea. Where as if you buy the bushings, they're ~$60/shipped. Then you have to take the time and or pay labor to have them pressed out and new one back in...
I just had this done on my '06 TSX
Bought new LCA's off of Rock Auto .com
The following 2 users liked this post by CL9 Jon:
D's Up (05-01-2014), S2kTl6 (04-29-2014)
Old 04-29-2014, 02:58 PM
0utl's Avatar
I am about to replace all of my bushings as well and was going to use the 07-08 Compliance Bushings on my 04-06. I have heard the 07-08 are softer but are they less prone to cracking is that why Acura made them softer?
Is this a good idea or should I just use the 04-06? I will be putting in type S shocks at the same time too.
Old 04-29-2014, 03:12 PM
TLX-S
wilztlxs's Avatar
logical sense.
I know what you mean about the car being stiffer in cold weather compared to warmer weather. I felt this too when I had my RSX-S. I always thought it was just the shocks due to the weather.
My compliance bushings have the slight crack that's considered "normal" for them and have been that way for the past 2 years with no change, no issues with ride in city and highway driving. My '04 TL currently has 97600 miles.
Old 04-29-2014, 06:20 PM
Anyone know if there are bushings in the subframes that participate in ride quality?
Old 04-29-2014, 06:29 PM
96SC4's Avatar
the complete LCA's on the TL are more than $70....
Old 04-29-2014, 09:11 PM
cokorote's Avatar
Great thread. I know this is about bushing but I changed the raxle and new shock and that make all the difference on ride quality on TL. It was like brand new car and "nice and sturdy feeling or tight". But I'm going to change the LCA bushing to the aftermarket one when the oem get cracked badly.
Old 04-29-2014, 09:23 PM
Fearless DIY Guy
DeathMetal's Avatar
Looks like this beast hasn't been slain. The TL lasts, so maybe there's a fix. My wife's 2013 RAV4 has a tighter ride than my 2006, 156k mile TL.
All said and told, it looks like we're at $450 for parts alone if we go HAM on the issue.
As of this point in time, here's where I'm thinking the culprits lie, and I'm contemplating whether or not I bite the bullet and do it. Let's assume (a) The tires are in good shape, (b) alignment is in spec, (c) wheels are not out-of-round, and (d) suspension is in good, working order
I could completely be talking out of my ass, but this is a thread for generating ideas, so let's keep it constructive
SUSPECTED ROOT CAUSES
1.) Fatigued / oxidized rubber bushings (all)
2.) Fatigue of mechanical fasteners (mild elongation)
3.) Disposition of nut / bolt head from original fastened position
4.) Improper torque value on fasntener
ORDER of OPERATIONS
CONTROL ARM BUSHINGS
1.) Compliance Bushing (51394-SEP-A01) - $28
2.) Front Arm Lower Bushing (51393-SEP-A01) - $22
3.) Shock Absorber Bushing (51810-SDA-A01) - $16
SECONDARY ITEMS
4.) Front Stabilizer Link (51320-SDA-A05 / 51321-SDA-A05) - $16
5.) Upper Arm Assembly w/ Knuckle (51450-SEP-A02 / 51460-SEP-A02) - $55
6.) FSB Bushings (51306-SEP-A01) - $3
7.) Front Ball Joint, Lower (51220-SDA-A0) - $64
I think I'm going to shop around and see what labor would run on all of this...I just don't have the time to do it myself, but I think this should solve the problem?
Old 04-29-2014, 09:24 PM
Fearless DIY Guy
DeathMetal's Avatar
At +150k, I can speak from experience that this is insufficient at this stage of wear.
Old 04-29-2014, 09:25 PM
Fearless DIY Guy
DeathMetal's Avatar
Add $200.
Old 04-29-2014, 10:25 PM
Moved to the LOU
twigglius's Avatar
ORDER of OPERATIONS
I ordered all those bushings plus nuts, bolts and washers. I also ordered ingalls arms since my stock arms are seized... Check my thread for pics of the parts... I have more that should be here by Friday. Once I get them all I will upload everything in here as well.
Old 04-29-2014, 11:45 PM
Please keep us updated. And try to objectively ascertain the ride quality difference. I dont know how... but maybe there are others that can help with devising a way so its not just a subjective review.
Old 04-30-2014, 07:11 AM
CL9 Jon's Avatar
Add $200.
They're $71.79 ea. for an '08 TL on Rock Auto .com
Old 04-30-2014, 09:19 AM
6spd FTW
Tehvine's Avatar
I would suggest adding new sway bar end links too. I was going to do the compliance bushings on my car before I sold it and noticed the end links were rather rusty. Fully expected to have to ruin one or more pieces of the hardware in the process.
Old 04-30-2014, 09:52 AM
CL9 Jon's Avatar
Oh absolutely... end links threads are always ruined... just better off to buy/replace them.
Old 04-30-2014, 10:39 PM
Moved to the LOU
twigglius's Avatar
Here is what I have so far.
51394-SEP-A01 - BUSH ASSY., FR. COMPLIANCE - $27.71 - x2
51393-SEP-A01 - BUSH, FR. ARM (LOWER) - $21.87 - x2
0181-S84-A00 - BOLT, TRAILING ARM (12X68) - $1.70 - x4
90215-SB0-003 - NUT, SELF-LOCK (12MM) (SATO RASHI) - $0.84 - x2
90119-SEP-A00 - BOLT, FLANGE (14X100) - $4.11 - x2
90124-SEP-A01 - WASHER, PLAIN (14MM) - $1.91 - x8
90122-SEP-A00 - NUT, FLANGE (14MM) - $1.33 - x2
90123-SEP-A01 - WASHER, PLAIN (12MM) - $0.64 - x4
90181-S84-A00 - BOLT (12X68) - $1.70 - x4
90215-SB0-003 - NUT (12MM) - $0.84 - x2
90119-SEP-A00 - BOLT, FLG (14X) - $4.11 - x2
90122-SEP-A00 - NUT, FLANGE - $1.33 - x2
I have an additional list of parts I decided to order today. Will post that tomorrow. Left the list in my car.
Old 04-30-2014, 11:25 PM
8th Gear
J2008navTL's Avatar
awesome list of parts
This gives me a better idea of what to expect but I only have 67k on my 08tl.
Old 05-01-2014, 12:35 AM
OP, if you want to start doing ball joints too, there's outer tie rods and inner tie rods.
i dont know if i would trust mevotech's bushings....I would definitely prefer OEM
Old 05-01-2014, 12:42 AM
Codename Duchess
DiamondJoeQuimby's Avatar
keeping an eye on this. I'm about to do shocks and I'm all for "while I'm at its"
Old 05-01-2014, 12:46 AM
Mr. Detail
Scottwax's Avatar
Replaced worn LCA bushings with Moog and upgraded to the solid TL Type S front anti-roll bar. Front end feels noticeably tighter. Was a little jittery on on off ramp near me, now it tracks straight through it. FWIW, I had a little over 150k miles on my car and front struts were replaced about 30k miles ago.
Old 05-01-2014, 08:29 AM
Fearless DIY Guy
DeathMetal's Avatar
ORDER of OPERATIONS, UPDATED..APPROX. +$600
SECONDARY ITEMS
8.) Outer Tie Rod (53540-SEP-A02) - $40
9.) Inner Tie Rod (53010-DSA-A01) - $51
10.) Gearbox Mounting Bushing (53685-SEP-A01) - $6 x 2
Old 05-01-2014, 10:10 AM
CL9 Jon's Avatar
Why do you say that? Yes, OEM is indeed preferred for most. But the prices are a joke and the performace is the same as Moog/Mevotech
SECONDARY ITEMS
If you're doing all that might as well do wheel bearings too since they'll be taking the axles out of the hub to do the balljoints.
My labor for just swapping my LCA's, endlinks, and (1) ball joint was $125... @ $55/hr
Old 05-01-2014, 10:20 AM
cokorote's Avatar
What about the top hat?? Aren't they part of bushing? I replaced the base top hat with type s when I changed the shock.
Old 05-01-2014, 02:41 PM
0utl's Avatar
AcuraPartsforless.com
SECONDARY ITEMS
Buy with Acurapartsforless there prices are the cheapest i found online and i saved over $40 and even up to $60 compared to some places with my order. I just purchased The parts 1,2,3, and 7 from your list & compared to your prices just adding it up would save you almost $20. Not much but it will add up. Like Part 8: 53540-SEP-A02 is $33 and you will need 2 so that is another 14$ hope this helped your wallet! They also had the lowest shipping cost!
Old 05-01-2014, 09:37 PM
I really think the subframe bushings are what's causing the sloppy deterioration in ride quality. I've had almost all these parts replaced and didn't do much.
Old 05-01-2014, 10:09 PM
Fearless DIY Guy
DeathMetal's Avatar
Seriously? Can you elaborate? I'd expect to have a much more pronounced effect. Mileage? Thanks for the feedback.
Old 05-01-2014, 11:46 PM
Current mileage is 123k. Over a span of 3 year or 20k miles I changed the following:
1. Both Lower Control Arms
2. Inner and Outter Tie Rods
3. Steering Rack
4. All 3 Engine Mounts
5. Sway Bar Endlinks
6. Sway Bar Bushings.
7. Replaced to TYPE S Suspension Top Hats and Bushings for Suspension
8 Replaced both Upper Control Arms
9. All 3 Transmission Mounts
All of this was done at Acura with OEM parts in order to fix the loose feeling which it really never did. It felt like it did for a day or two but then it was evident it didn't (placebo effect). Then when my transmission took a dump and they replaced it, I felt almost instantly my car gained 30% of its stiffness back. The only thing they changed at this time was the transmission and nothing else.
The only theory I could come with is that they dropped the subframe and when they mounted it back up all the bolts were re-torqued and tightened and hence eliminating the flex in the body and holding all the other parts listed above in place as well. However fast forward 7 months later and its now starting to feel loose again. This is why I think the issue is surrounding the subframe rather than all these other components.
The entire engine is mounted and sits on the subframe. If the subframe bushings have more play in it, this could cause the body to flex more during driving as the weight of the engine is not be supported firmly and cause body roll and sway. Keep in mind the engine mounts would be normal and good. I could be totally wrong but this but this is my theory.
Old 05-02-2014, 05:48 AM
CL9 Jon's Avatar
Those don't exist
Quick Reply: Higher Mileage Crew, let's talk BUSHINGS!
