HID Temp Question
Old May 2, 2005 | 07:19 PM
05TLsam's Avatar
no soup fo u!
HID Temp Question
Anybody know what the factory temp for the HID bulbs in the 05 TL is. IT looks to be on the low side for HID's and I want to make it a little more whiter.
Also looking for bulb number specs so I can change this and the fogs, anybody? I looked at a website and they said two different numbers for high and low beam but I thought these HID's were all in one. Isn't that what bi-xenon means?
Old May 2, 2005 | 07:54 PM
caball88's Avatar
you mean the color temperature right? its 4300K, all factory hids are in this temperature range. the TL has b-xenons being that the hid bulb is used for both the low and high beam. when you switch on the high beam, the hid light is reflected into the high beam housing via a silenoid and hence chaning the light output.
dark inspire's Avatar
El Presidente
Im pretty sure the stock HID temp is 4300k, and teh bulb type is D2S, which is made for the projectors.
Old May 2, 2005 | 09:39 PM
crazymjb's Avatar
Take a pic of the stocks, and then of the new color. I like the darker blue, not aqua, but not violet.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
06TLMatt
Oct 2, 2015 08:14 PM
navtool.com
Sep 25, 2015 05:15 PM
