HID question
Old Mar 24, 2012 | 11:48 AM
ep3kid914's Avatar
HID question
I bOught some new hid bulds d2s 8000k 55w was working good and everything but yesterday the passanger went off it would flicker on and off at time till it gave out yesterday i changed to the oem ones today but they still dont go on idk what the problem can be? Were would the fuse be for the hid? Anyone?
Old Mar 24, 2012 | 11:59 AM
VanyDotK's Avatar
Your first problem was buying ricer 8000k bulbs. Second problem, running 55w bulbs with, I'm assuming, factory 35w ballast.
Are both headlights going out or just one? If it's just one it's probably not the fuse, it may be the igniter or ballast.
Old Mar 24, 2012 | 12:10 PM
cpm06wdptl's Avatar
^^I agree with him!! If they flickered before they went out then it's not a fuse. If it was a fuse they would have just shut off suddenly without a flicker. Start with the ballast and go from there. Also with 8000K bulbs your light output isn't going to be as good as factory which is 4300K.
Old Mar 24, 2012 | 12:31 PM
ep3kid914's Avatar
Just the passanger went out yes i guess learn fRom our mistake never buying these cheap hid bulbs again were would i be able to get the ignIter or ballaast
Old Mar 24, 2012 | 12:56 PM
wtf8269's Avatar
Does the bulb flicker upon ignition but not stay lit, or does nothing happen to it at all? If it flickers but doesn't stay on, there is probably a loose connection and you could try adding some dielectric grease to the connection.
Old Mar 24, 2012 | 07:08 PM
ep3kid914's Avatar
It dont turn on nomore idk wat can it be
Old Mar 24, 2012 | 07:29 PM
ep3kid914's Avatar
Would any electrical Place that does hid be. Able to fix it or do i need to take it to acura? And were can i get the parts like part numbrr mines in an 2004 tl base
Old Mar 24, 2012 | 08:00 PM
VanyDotK's Avatar
My head hurts..
Old Mar 24, 2012 | 08:59 PM
swoosh's Avatar
takin care of Business in
ok here is what i suggest:
swap the bulbs side to side...if the problem moves with the bulb, bulb is the culprit....if it doesnt then you should start troubleshooting for ballast/igniters.....
Old Mar 24, 2012 | 09:11 PM
ep3kid914's Avatar
I swapped back to oems bulbs still dont turn on ima take it to the electric shop to check whats wrong
Old Mar 24, 2012 | 09:15 PM
swoosh's Avatar
^^^ did you even read my response ???
Old Mar 24, 2012 | 10:16 PM
nightkid08's Avatar
it's most likely your bulb is your culprit like swoosh said, but if it isn't its probably your ballast like others have said. to eliminate this problem in the future have a relay harness for your hid kit.
Old Mar 24, 2012 | 10:20 PM
VanyDotK's Avatar
He doesn't need a relay kit for his factory HID ballast.
Old Mar 24, 2012 | 10:37 PM
nightkid08's Avatar
whoops, for some reason i thought he was talking about fogs. my apologies for the wrong info
Old Mar 24, 2012 | 10:47 PM
Azndjay's Avatar
MV612
well what kind of brand did you get to begin with let's start with./?
Old Mar 25, 2012 | 12:24 AM
RainSupreme's Avatar
If he's trying to run 55W bulbs from the factory 35W harness, he would need a relay
Old Mar 25, 2012 | 12:26 AM
VanyDotK's Avatar
No, if he were running 55w bulbs, he should be running a 55w ballast then he would change his headlight fuse to a higher rating.
Edit: The only 55w bulb I would run are the Philip DL50 bulbs + 55w ballast. I ran these on my S2000 retrofit without any brunt chrome issues.
Old Mar 25, 2012 | 12:36 AM
He should be you are correct but I doubt he was. From reading his first post looks like he just stuck the 55W bulb into the factory setup
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
