HID bulb swapping
HID bulb swapping
I am in the process of buying HIDs. I was wondering if I can just buy the bulbs and swap them with the old ones or do I have to buy the ballast also. BTW I am buying from ddm
I picked up some HID Bulbs for $30 bucks that are 8000k. I like them better then the OEM bulbs. Just look around and find good price before buying your bulbs. Ballast usually last a long time especially the OEM Ballast since most of them are German Manufactured. The Japanese versions tend to go out faster and aren't as reliable as the German ones. GL
You do know that if you run a 3000k bulb, your headlight output will be significantly less than the stock 4300k bulbs, right? Run 3000k bulbs as your foglights, not headlights. If you care about performance, 4300-5000k the brightest. If you're only into appearance, 6000k (and up) will be nice and blue/purple.
http://www.theretrofitsource.com/pro...g2vpvae8k6ggbf
8000k is too blue which are even less bright that oem 35watt 4300k systems in all other cars. I did 6000k set-up on my 08 accord coupe and was made when a bmw 335i sedan came beside me and was so much brighter than mine. After that i swapped to 5000k set-up. I'll be going frome 4300k to 5000k on the TL soon. People buy HID's i thought to see more of the road. Not less.
07-16-2017 08:33 AM
AmplifiedDetails
09-24-2015 03:55 PM
