Help voltage gauge install ?
Old 05-10-2014, 05:49 PM
StormTrooperTL508's Avatar
Hi does anyone on here know how to install a voltage gauge ? I ordered one and have no clue on how to wire it. Thanks in advance!
Old 05-10-2014, 07:37 PM
dcmodels's Avatar
EVERSTART BATTERY MONITOR VOLTMETER p/n 932W:
This inexpensive digital device measures between 8.0 and 19.9 volts DC. It displays only to a single decimal point. It draws 0.1 amps because it has 3-LEDs and the 3-digit display. The device was purchased from Wal-Mart.
Since I do not own a ‘real’ digital volt meter. I have no way to calibrate or verify the accuracy of this simple device. It is useful only to give comparison readings during charging. However, compared to some other DCVMs that I have, it seems to be accurate to one-half (0.5) volts.
This device is useful in indicating any problems with the vehicle charging system, e.g., the alternator. For example, the Acura RDX voltage should read between 13.5v and 15.1v when the engine is running, from the factory specification. The device can be plugged directly into one of the (cigarette-lighter type) charging ports on the dash, which will give a reading only when the engine is running.
This voltage-meter device can also be used as an alternative to a Load-Test, by verifying that the battery voltage is between 9.5-10 volts (minimum) during an engine start.
But seriously, you must use the instructions with the gauge that you purchased, as every gauge will differ slightly in wire-up.
But where do you intend to install the new gauge? I could not find a place on my RDX, which is why I bought the plug-in type.
Old 05-10-2014, 07:38 PM
splew's Avatar
You connect positive side of the gauge to any ignition switched 12 volt power source (cigarette lighters/power outlets are popular) and you connect the negative side to any chassis ground.
Old 05-10-2014, 09:08 PM
But there's a third wire ?
Old 05-10-2014, 10:16 PM
PhiSigBrotha's Avatar
Backlight illumination? No idea unless to tell us what brand/model it is.
Old 05-10-2014, 10:33 PM
Fearless DIY Guy
DeathMetal's Avatar
^^^This. A third wire is typically employed where a means for display current is required.
Old 05-10-2014, 10:36 PM
Darren's TL's Avatar
The third wire is most likely a dim function ( dimming the gauge at night so it's less blinding)
I never hook it up because the regular brightness doesn't bother me.
If you wanted to hook yours up you would just have to splice into the head light circuit. It won't draw much power, its just uses the headlight power as a switch to turn on the dim function.
Old 05-10-2014, 10:51 PM
http://m.ebay.com/itm/251494678580?txnId=1434088647015
Old 05-10-2014, 10:54 PM
bp_spets's Avatar
It says it comes with instructions.. read the instructions!
Old 05-10-2014, 10:58 PM
Make sure you put a fuse in-line on the positive wire. It should tell you what size but if it doesn't, I run a 5 amp fuse for mine in my prelude.
Old 05-10-2014, 11:02 PM
All the instructions say is nothing it's just a picture from from my battery and one to my ignition ??
Old 05-10-2014, 11:12 PM
Fearless DIY Guy
DeathMetal's Avatar
It's wired to a switched source to prevent from pulling current when the vehicle is not in use. It'd drain the batter otherwise.
Old 05-10-2014, 11:15 PM
Oh, OK. some that means one wire is the constant power( what the gauge measures) and one is the turn on wire. So wire one to a constantly hot source and one to a source that only hot/live when the ignition is on. You can tab into a fuse on the inside fuse box that is hot only when the ignition is on. The picture should show you what color wire does what.
Old 05-10-2014, 11:18 PM
Fearless DIY Guy
DeathMetal's Avatar
Yes
Old 05-10-2014, 11:22 PM
Remember like I said before run an in-line fuse on the constant wire, close to the source. I know I'm repeating myself but its very important. I use a 5 amp fuse.
hedzup
1G RL (1996-2004)
06-29-2016 08:07 AM
BoricuaTL
04-08-2016 01:08 PM
mrkingstonvi
02-22-2016 01:53 PM
TxRzrBk
09-17-2015 01:07 PM
HeloDown
09-08-2015 06:51 PM
Quick Reply: Help voltage gauge install ?
