Help!! Need to buy OEM parts
[T]he [L]egacy
I need help finding OEM parts for a 100k
I need a Timing belt
Water pump
Auto Tensioner for drive belt and a drive belt
Water pump
acuraoemparts.com that where I go every time.
Registered but harmless
Received 1,107 Likes
You can do a search and find all kinds of info on the timing belt change and kits in several timing belt change threads here.
[T]he [L]egacy
i went to acuraOEMparts before posting and I just don't want to get the wrong part. for example When i looked at the timing belt piece, its like #5 pointing at the belt but is that all i need? where is this Kit that you speak of @Will Y.
Per poster cazio above, check oemacuraparts.com-- call and ask for Tim Poloniak.
Otherwise, Rock Auto has the full kit with belts, tensioners, water pump, bearing, etc. per lucnex. IIRC, it's a more complete kit than the Amazon kit, which doesn't include the serpentine/acc drive belt.
Yes the Gates brand kit from RockAuto.com with the prefix TCKWP is the one to get. Everything is OEM except the water pump. Yes Gates/Unitta makes almost all of Honda's OEM-Honda branded timing belts. My B18C Type-R timing belt says Unitta right next to Honda, and it's made for a motor that has a stock redline of 8900rpm (B16B). So no worries about quality, strength or longevity.
- The belt is Gates (Honda is Unitta which is Gates brand name in Asia)
- The bearings in the kit are Koyo (just like Honda ones)
- The tensioner is Aisin (just like Honda)
- The water pump is Gates (Honda's is Yamada)
The Gates brand water pump is still top quality. I put one on my Pilot and my TL will get one when the time comes.
handsom-hustla
11-13-2015 05:04 PM
nanos
11-12-2015 08:41 PM
