Help for maintenance and tune up
Old Jun 8, 2011 | 12:04 PM
naser075's Avatar
Hello every1,
I got a 2005 TL with a spec skirt kit (don't matter really). I have 83000 km = 51573.808 mi. (google). Now I have done complete transmission flush with redline, brake fluid flush, prestone flush all at 50000km or 26000 miles, oil changes at every 5000 km with mobile one syntetic oil.
What can I do for maintenace? should I change spark pluggs if yes which kind? Anything else you guys can provide .
Also I gte bad gas millage and am not a rough driver 170 km ( 105 miles) with half a tank I find that poor
thank you in advance
Old Jun 8, 2011 | 12:11 PM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Originally Posted by naser075
Hello every1,
You don't have to change your spark plugs, but it might help. Denso iridium spark plugs are good ones to get.
Check your air filter and either replace it or get a quality K&N air filter. If you're so inclined, replace the in-cabin air filter also. As far as the bad mileage goes, how are the tires? Have you checked the air pressure? It should be between 30-35 PSI all around.
And I hope you didn't do the flush, and you meant a drain and fill for the transmission.
Old Jun 8, 2011 | 12:33 PM
naser075's Avatar
ohh sorry,...yes air filter was replaced not cabine. tires are 2 years old maybe 25000km on them always at 34 psi.
Transmission: I brought it to tranmission specialist he putt it on some type of machine and I needed 12 liters (45 galons) to fill tansmisssion again
So not much I can do on it right
MrHeeltoe
20
Feb 23, 2023 01:54 PM
LeVeL
Oct 18, 2015 04:19 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
