Hella universal LED daytime running lights on my '06 TL
#41
takin care of Business in
Received 4,732 Likes
#42
Received 6,470 Likes
The LED's look classy on the 4G.
#43
^ Yes they arrived. I got the lights on Thursday. I will need to cut into the black plastic inner cover as well to get a flush install. My new lights have a 74mm max depth which is actually less than the Hellas are at 86mm (according to the Hella website).
I was hoping on doing the install by just removing the grill inserts instead of the entire bumper so I'm planning this a little more.
#45
I think I'm going to abort this install and actually get another type of light from iJDMToys instead. They have an Audi A6 Style light that looks like it will fit much better for our space cavity. Here's the link: http://store.ijdmtoy.com/Audi-A5-A6-..._drl_sku77.htm
This light is longer but has a much less depth requirement so I shouldn't need to cut that back bumper plastic too much if at all. (I might slice it to use a bracket provided by the light though). I was worried about the cutting and also just how the light would be installed.
I have to say the JDMToys lights look of good quality and are very bright so I want to continue my efforts- just not with this Hella light style. Even if they don't take my return, I'll be ahead. The Hella's should work good on my Pilot.
#47
Thanks.
#48
Carpe Ominous
#50
sorry but NOOOOO !!!!
Xmas is still 10 months away....try to keep it clean....I have been a victim of "over" modding....i would rather spend the $$$ on a front aspec lip
#51
^Yes- that's a bit over-done and will cost you 450 for Hella or almost 200 with ijdmtoys. You would be wacking most of that back plastic backer panel too which is used for clipping in the inserts.
#52
^What he said.
#53
Yea that seems to be the consensus at least here. I photoshopped the lights on four different locations and have been getting opinions. I'm used to the big 2nd gen fogs with 6000K Hid's in them. Yours still looks the best to me but the quad one leads the non-acura office pool 2 to 1 did you consider the bottom row?
#56
#57
According to ECE (European) regulations, you're not supposed to mount DRLs any lower than 250mm (9.8 inches) from the ground, so I think mounting them in the lower slot of the grilles would put the below that. Granted, here in the U.S. we don't have such strict regulations governing DRLS, so it doesn't really matter, but I still think the European regulations are good guideline to follow.
#58
^^^ aaah....sorry i did misinterpret you statement....
swoosh (02-22-2012)
#60
Previous Owner
I'd love to see an install vid or pictures. I'm considering these
http://www.carid.com/universal-light...ts-326562.html
the 004 ones which look like the jdm ones you bought.
I'm trying to figure out how to wire it. what did the JDMs come with? I'd like to have the lights stay on all the time when my car is on without turning on any lights but turn off when my car is off. Without me hitting any switches.
#61
I hope that helps.
#63
Yeah, here's basically what I did (excuse the crudely drawn wiring diagram). Note the relay shown in the diagram was a part included in my Hella kit, not something that originally came with the car. The green wire has 12 volts when the key is in the on position. The power from the green wire is used to energize the relay, which closes the switch, sending power to the lights.
#65
No need for a relay since the lights draw very little power and I want them always on anyway.
#67
And yes, my Hella DRL kit came with a relay, but I don't think the knockoff kits do.
I guess that's another way you could do it. Which fuse location did you use?
#68
I just found this, which will allow me to not have to do any wiretaps
http://store.ijdmtoy.com/Daytime-Run...uto-switch.htm
Yay
Yay
#71
whats happening to the TL's ??? are they getting wayyyy to affordable ?
#74
I got the flexible strips (from JDM) and hope to install this weekend. They are 3x brighter than my current strips and should look pretty good. I'm going to install them on the top/outer edge of the black grill inserts. I still like the 'stealth' look where the lights are not so obvious when the car is parked- this new placement will fit that design goal for me because the bumper lip will hide the strip pretty well.
Photos will be coming later in the weekend.
#79
Previous Owner
