Heater is off
WDP Director of R & D
Re: Heater is off
Originally posted by desijatt
but still gives heat........
Smitty
Re: Re: Heater is off
Originally posted by KJSmitty
The TL has a temp sensor in the drivers seat - it could tell you were still cold...
Smitty
Smitty
Team Nighthawk Spokesman
You have to adjust your temp. to what ever you want...even is your climate control system is off it still must blow air in your car and you can control that temp. So set it to cold and see if that fixes it or whatever temp you want. Not sure if this is the issue you are talking about but hope it helps.
Moderator Alumnus
Re: Heater is off
You turn off the Climate Control, but still allow outside air coming in? I know in some cars, if doing so, you should feel heat from vent when your target temp is much higher than your inside temp.
Biggie_B
02-26-2017 11:14 AM
