Headlights stats
Headlights stats
What are the stock stats for the 05 headlights, daylights, & fogs I was going to install new headlights and going to replace all 3 whats the stock housing for? HID? LED?
oh man you gotta replace the bulb? im gonna assume since you're asking about bulb fitment you probably havent replaced a hid bulb in a 3rd gen TL before
just a heads up you're going to need to remove the front bumper, headlight bracket supports, and the actual headlights to replace the bulb.. you'll also need a somewhat special tool, a T20 *Security Torx Driver.. and i say security torx driver because a regular T20 wont work.. the screw that covers the cap has a special bump in the middle of the screw that requires a security torx driver
now there are a few DIYs on here and on youtube that show you how to replace the bulb without removing the bumper or headlight and i have tried those methods but those methods only create more frustration especially if its your 1st time because of the tight space you have to work with and the bulbs on my car have never been changed before so that T20 security screw was on there factory tight
