headlight blinkers
Old Mar 22, 2009 | 03:39 PM
jpmunoz's Avatar
headlight blinkers
can someone please post instructions on how to replace the front blinkers? i searched everywhere and i cant figure out how to replace it. thank you in advance.
Old Mar 22, 2009 | 05:36 PM
voigt's Avatar
Just from memory if you turn the wheel in (if you are working on the left turn wheel right). There are clips that hold the black wheel well liner in. Take them out and pull the liner back. Once that is done you should be able to see the cable. Reach in and turn the harness and take the bulb out. Just repeat in reverse to finish.
Again this is from memory. I hope this helps.
playa4real's Avatar
for the drivers side: turn your steering wheel all the way to the right, loosen the wheel well lining, pull back and replace bulb that way.
for the passengers: turn your steering wheel all the way to the left and follow the same instructions above.
edit: voigt
Old Mar 22, 2009 | 05:42 PM
playa4real's Avatar
take a look at this thread for scans. i think the owner's manual also tells you how to do so. look up the instructions for fog light bulb replacement..
https://acurazine.com/forums/3g-tl-2004-2008-93/how-do-you-change-front-signal-bulbs-570039/
Old Mar 22, 2009 | 08:17 PM
jpmunoz's Avatar
you guys are ill, thanks
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
