Gum!!!
Old Aug 18, 2004 | 02:43 PM
Iceman23's Avatar
Certified Hater
Gum!!!
after i parked my car at work today i get out and noticed gum was stuck to the entire right side of my car.. it looks like it was done on purpose too!! how would you recommend i take it off?
Old Aug 18, 2004 | 02:51 PM
dwcolt's Avatar
I would recommend burning it off, assuming that your car has been Zainoed.
I'm guessing that a simple wash with a bit more car wash concentrate than usual would be more than enough to take it off- perhaps let it soak for a couple of minutes before re-soaping. If it's really ground in there, a little WD40 will kill the stickiness of gum instantly and then you can simply repolish the areas where it was removed in order to protect the finish.
Good luck. And find the bastard who did it.
Old Aug 18, 2004 | 02:53 PM
vtechbrain's Avatar
WD40 is the trick!
Old Aug 18, 2004 | 02:54 PM
DanL's Avatar
Bug and Tar Remover may work, but if not, Goof-Off almost definitely will. But as always, try it on an inconspicuous place first. You'll obviously need to wax the area afterwards.
Old Aug 18, 2004 | 02:55 PM
leo221's Avatar
regular gasoline should melt it.
JTL__ACURA
Dec 11, 2007 11:19 AM
stogie1020
Wash & Wax
Aug 7, 2007 12:23 PM
